I'm running WeeWX on a raspberry pi connected to a FineOffset WH1080 and would like to add a webcam snapshot to my weather page. I added a Raspberry Pi NoIR camera to the pi and set up the pi to take an image once every 5 minutes. So far, so good.
My NoIR version of the Pi Camera has no infra-red filter built in and comes with bit of filter material to insert into a case (ordered, hasn't arrived yet). The attachments show the difference between filtered and unfiltered views. (See also:
https://raspi.tv/2013/pinoir-whats-it-for-comparison-of-raspicam-and-pi-noir-output-in-daylightI tried adjusting the saturation which one can do with a command line, like so
$ v4l2-ctl -c saturation=XXbut found the results disappointing.
I noticed that some other webcam programs allowed one to tweak hue, saturation and white balance interactively and I tried out cheese, camerama, gucvview and webcamoid in quick succession, with an old USB Logitech camera plugged in and entering
-d=/dev/video1on the command line. I didn't succeed in getting what I hoped for: a live feed that would let me tweak the parameters I could then use with the raspistill image capture program. I think the problem was somehow related to the programs defaulting to the default video device at /dev/video0 device, I'm not really sure.
I'm wondering
1. If there are any settings for the Pi camera that will give me a decent image, colorwise
2. What software I can use play with the settings and what I have to do to give it access to /dev/video0
The images at the link above on the
raspi.tv site do not show the corrected (filtered) NoIR image. In principle I understand that the NoIR plus the filter should be similar to the filtered image, but so far I have't seen green fields looking green. Wondering if anyone else has had to fiddle to get this working? If so, how?
I have a PoE Ethernet switch in my attic and a spare Ethernet cable run to a box outside the house where I could mount a camera looking in the same direction as the Pi camera and if I can't get good enough pics with the Pi camera that is something I'll want to try (I have a webcam and PVR in place and ran a spare cable which I could use for this).
However, something I don't know and would welcome advice on is: assuming I want an image of, say, 640x480, for the purposes of a weather page photo, is there any merit in capturing with a camera capable of a higher resolution and adjusting either via downsizing or at capture, or is a lower resolution camera adequate? In essence, is a reduced hi-res image any better than a lower res image? Or does it depend on the camera?
If a cheap FTP capable camera with PoE support would suffice and free up a raspberry pi ... recommendations welcome! Thanks
Below: unfiltered and filtered images with the raspberry pi NoIR camera; fields are green in real life.
[ You are not allowed to view attachments ] [ You are not allowed to view attachments ]
