Author Topic: Ambient Weather PM 2.5 sensor  (Read 1567 times)
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • Living in the "Last American Frontier"
« on: June 07, 2019, 01:50:17 PM »
I have purchased and installed this to complement my WS-1401-IP array. It was an easy install and links through my Weather Observer IP bridge. Data is sent to Ambient Weather network. Sensor information here: https://www.ambientweather.com/ampm25.html
My station dashboard is here: https://dashboard.ambientweather.net/devices/public/cb606b61152ec0de5b4e6d97c5ab8af7
This sensor is very similar if not the same as the one from Ecowitt.
**EDIT** corrected dashboard address
« Last Edit: June 07, 2019, 03:57:25 PM by Weatheroger »
Re: Ambient Weather PM 2.5 sensor
« Reply #1 on: June 07, 2019, 02:09:42 PM »
Hope it does well for you. Yes it is the same as the Ecowitt with some minor differences internally (software). The Ambient version is the only one that will work with other Ambient consoles. The Ecowitt version only works with Ecowitt consoles. But the Ambient version will also work with Ecowitt consoles (from what others have reported) as long as the frequency matches. They are all made by Fine Offset.
Some info on sharing your Ambientweather.net dashboard. The link you posted is only a private link that only works for your login. In order to share your Ambientweather.net dashboard there are some extra steps you need to take.
  • On Ambientweather.net go to Devices
  • Select your Device to share
  • Click on the green Share button
  • Enable sharing by clicking on the "Make Public" button
  • Now you can copy the shared URL link shown
  • Finally share that URL link with whom you want
« Reply #2 on: June 11, 2019, 01:33:59 PM »
I am trying to get an answer as to what a PM 2.5 sensor will monitor. I know pollen and dust are monitored but will it track gasses such as O3? I am aware of the issues with humidity, dew and moisture collecting partials causing spikes. I can see spikes around 11-2 at night this is also when we get our highest concentration of O3 where I live.
Offline txweather.org
    • Texas Weather
« Reply #3 on: June 11, 2019, 02:25:53 PM »
Dust and Pollen are up to your PM10 range, PM2.5 goes to a finer particle or smaller.
https://airnow.gov/index.cfm?action=aqibasics.particle
To my understanding most consumer level products do not have an Ozone (O3) sensor (Gases)... (Unless you pay premium)
And note that they are not in the same particle spectrum (Gas).
« Last Edit: June 11, 2019, 02:37:57 PM by txweather.org »
Offline havtrail
    • Haverford Weather Station
« Reply #4 on: June 11, 2019, 03:46:34 PM »
Ground-level ozone (03) needs a whole different sensor. In many areas of the U.S. the critical air pollutant is ozone, not particulate matter, especially in hot sunny weather.
It is also erroneous to call a PM sensor reading "air quality." Air quality and the Air Quality Index (AQI) depend on a combination of pollutants, not just PM, so if you are measuring just one pollutant you really cannot calculate an AQI number.
Rich K.
Onset HOBO RX2102 Cellular
