Author Topic: Alternative-Dashboard Version 6.21  (Read 151699 times)
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
Re: Alternative-Dashboard Version 6.07
« Reply #200 on: January 23, 2011, 10:09:58 PM »
Hi Scott,
Thanks for the recent upgrade.  Looks like most of the fixes are working.  Although, some fixes were minor and I don't have freezing temps here so far, those fixes are welcome for those that have that changes is temps.
Thanks for all the support that you have provided.
--Stan Y.
   Maui, Hawaii
Thanks Stan, most appreciated.  I know you have helped with bugs too, it really takes time to find some of them and everyone's help is always appreciated!
Scott
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #201 on: January 24, 2011, 04:03:24 AM »
Hi Scott,
Haven't gotten to v6.07 yet, but I did find a problem in v6.06 that may have been carried over (this was not in previous versions).
Around line 1326 is...
echo "<span style=\"font-size: 85%; \">Data Not<br />Available</ span><br /><br /><img src=\"./ajax-images/AQI0.jpg\" alt=\"Data Not Available\" />";There are two spaces in there that shouldn't be - actually one is more personal formatting, but the other causes a validation failure.
1. Not a biggie - the space between 85% and the \ can come out (just a code formatting thing).
2. After Available you have </ span>. That should be </span> (no space). This one causes the validation failure.
So the final code would be...
echo "<span style=\"font-size: 85%;\">Data Not<br />Available</span><br /><br /><img src=\"./ajax-images/AQI0.jpg\" alt=\"Data Not Available\" />";
You told me to keep finding stuff...   :roll:
W7JKG
« Reply #202 on: January 24, 2011, 07:45:27 AM »
Hi Scott,
Will be fixed in the next version!  Thanks!
Scott
Offline klamort
« Reply #203 on: January 24, 2011, 12:53:49 PM »
I am still having a small problem... with the translation... In the current conditions, it is always written "It is" You can see it here: http://www.voyage-moto.be/?page_id=1156
I tried to change it in ajax-dashboard.php on line 467...
But it still does show up. Is there another place where I have to make the change also.
Also I am missing quite à few Icons for the windrose, is there à place I can download them.
« Reply #204 on: January 24, 2011, 07:33:57 PM »
You will find it in ajaxWDwx.js too
Scott
Offline youngros
    • Sans Souci Weather
« Reply #205 on: January 27, 2011, 08:03:47 AM »
Quote from: youngros on January 05, 2011, 07:47:18 AM
Hi Scott,
CSS is improving slowly http://www.mad-weather.com/ajax6.php the one thing I seem to have missed is how to keep the UV image showing, it shows briefly when you press F5, but it's not there all the time.
I also had the all time station record showing 1/1/1970 but on your high lows trend script it was showing the correct date so I changed
<?php echo create_datemdy($recordhightempmonth,$recordhightempday,$recordhightempyear)?>
to
<?php
                      if ($WDdateMDY)
                          echo fixup_date($recordhightempmonth . "/" . $recordhightempday . "/" . $recordhightempyear);
                      else
                          echo fixup_date($recordhightempday . "/" . $recordhightempmonth . "/" . $recordhightempyear);
and that now works. Interesting to note that it was only the high temperature that was affected and not the low or warmest coldest days and nights.
Rosalind
If it disappears right away it's the ajax java script that is updating it.  You have something set wrong in that.  What does it show?
Scott
Hi Scott, sorry for the delay in replying.
What am I supposed to be looking for on the ajax java script?
Pleased to have been of some help with the above script.
Rosalind
« Reply #206 on: January 27, 2011, 08:52:55 PM »
Rosalind
Rosalind
I see you have version 6.02 and there have been several changes since then that I think will help improve how things work for you since you're using metric readings.  You should download the update, replace your ajax-dashboard6.php and ajaxWDwx.js files with the ones in version 6.07.  That will help several things.  Can you send me a screen shot of what you see in the daytime in the UV section, when I look at it, its working well but it's still dark there!  I'll try to check it a bit later when it lighter there and maybe I can see it.  The link to the update is at the end if this thread.
I've also noticed an error in the Java Script, that is probably what is causing the script to stop before it finishes updating the UV.  The error I'm seeing is:
Webpage error details
Timestamp: Fri, 28 Jan 2011 01:55:19 UTC
Message: 'clientraw' is undefined
Line: 672
Char: 7
Code: 0
URI: http://www.mad-weather.com/ajaxWDwx.js
Line: 672
Char: 7
Code: 0
This probably means that the path to your clientraw.txt file (defined in both the settings file and java script file) is incorrect and it can't find that file.  Look for a line that looks something like this in both:
var clientrawFile = './clientraw.txt'; // location of clientraw.txt relative to this page on website
Updated 1/28/2011 - Just got a look at the problem and it is because you don't have the right images in the right spot.  It is looking for the UV images to be in the following location:
http://www.mad-weather.com/ajax-images/uv4.gif
Also make sure the file names are lowercase and in .gif format!
Scott
« Last Edit: January 28, 2011, 07:36:44 AM by WebsterWeather »
Offline stewart45
    • Newlands Weather Station
« Reply #207 on: January 28, 2011, 05:35:07 AM »
Just a small thing ,is it possible to have the two temp displays show the same, I'm assuming one rounds up
« Reply #208 on: January 28, 2011, 07:33:49 AM »
You can change the temperature rounding by either changing the gizmo to display the Temp with 1 decimal point or change ajaxWDwx-settings.js to make temp show with 0 decimal points.  There is a section that allows you to choose that in the settings under units of measure.
Scott
Offline stewart45
« Reply #209 on: January 28, 2011, 07:44:50 AM »
Thanks Scott
Offline youngros
« Reply #210 on: January 28, 2011, 08:47:54 AM »
Hi Scott, now got the uv images showing...images were uv01 instead of uv1
the clientraw.txt file is in the same directory as the ajaxWDwx.js so not sure what is wrong there.
I have downloaded the new files and will look at updating next week when I have a bit more time to spend on it.
Thanks for your help. Rosalind
Offline jgillett
« Reply #211 on: January 29, 2011, 01:10:25 AM »
Hi Scott,
Now that split() has gone bye-bye in PHP 5.3.x, will you be updating your stuff - sometime?   :roll:
W7JKG
Offline klamort
« Reply #212 on: January 29, 2011, 12:01:58 PM »
Hi Scott,
I see that you have enough work around here...
I am still having a small problem, with the record high and record low... you can see it here http://www.voyage-moto.be/?page_id=1156
The record high is really not right... but I am not sure if it is my configuration or weather underground or your script....
Thanks for your help...
Klaus
Offline CNYWeather
    • CNYWeather
« Reply #213 on: January 30, 2011, 03:42:31 PM »
But that 52.4 is mm though Scott. My avg. shows as 26.9 for January.
You may want to verify your snow setting in WD then.  I'm not sure why it would be in mm as by default it is stored in cm and then converted to in.  I double checked mine, it is right on with what WD says is my average.
Scott
I asked over at the WD forums, and Brian said that my testtags are correct and had no idea how
to get the tags to show up in cm like you have unless I convert I believe.
$avsnowjan = '13.5'; //Average snow for jan from your inputted snow data (cm)
$avsnowfeb = '25.7'; //Average snow for feb from your inputted snow data (cm)
$avsnowmar = '0.4'; //Average snow for mar from your inputted snow data (cm)
$avsnowapr = '2.1'; //Average snow for apr from your inputted snow data (cm)
$avsnowmay = '0.0'; //Average snow for may from your inputted snow data (cm)
$avsnowjun = '0.0'; //Average snow for may from your inputted snow data (cm)
$avsnowjul = '0.0'; //Average snow for jul from your inputted snow data (cm)
$avsnowaug = '0.0'; //Average snow for aug from your inputted snow data (cm)
$avsnowsep = '0.0'; //Average snow for sep from your inputted snow data (cm)
$avsnowoct = '1.6'; //Average snow for oct from your inputted snow data (cm)
$avsnownov = '9.2'; //Average snow for nov from your inputted snow data (cm)
$avsnowdec = '55.7'; //Average snow for dec from your inputted snow data (cm)
Tony
« Reply #214 on: January 31, 2011, 01:59:41 PM »
Klaus
Klaus,
I see your function for changing between metric and imperial is not working either, did you modify the code to show only metric readings?
Scott
« Reply #215 on: January 31, 2011, 02:07:45 PM »
/quote]
I have no idea why it would be different, I added in the tages a long time ago when I copied the lines from the file Brian included with WD of all available tags.  If it is actually in mm then somehow it must be converted as I do nothing to change the readings and I have heard of no one else having the problem.  At the top of the code, there is a section that selects which snow measurement to use, and it too assumes that it is in cm
// Snow setup
if (preg_match('|in|i',$uomSnow)) { // use USA measurements
  $snowseason = $snowseasonin; // Snow for season you have entered under input daily weather, inches
  $snowmonth = $snowmonthin; // Snow for month you have entered under input daily weather, inches
  $snowtoday = $snowtodayin; // Snow for today you have entered under input daily weather, inches
  $snowyesterday = $snowyesterday; // Yesterdays' snow
  $snownow = $snownowin; // Current snow depth, inches.
  $apparentsolartemp = $apparentsolartempf;    // Apparent Solar
} else { // use Metric measurements
  $snowseason = $snowseasoncm; // Snow for season you have entered under input daily weather, cm
  $snowmonth = $snowmonthcm; // Snow for month you have entered under input daily weather, cm
  $snowtoday = $snowtodaycm; // Snow for today you have entered under input daily weather, cm
  $snownow = $snownowcm; // Current snow depth, cm.
  $apparentsolartemp = $apparentsolartempc;    // Apparent Solar
I don't have a good answer for you, sorry.
Scott
« Reply #216 on: January 31, 2011, 02:08:41 PM »
Hi Scott,
Yes, I will look into that shortly and hopefully have something soon.
Scott
Offline CNYWeather
    • CNYWeather
« Reply #217 on: January 31, 2011, 02:16:06 PM »
Would you know where I can get a fresh copy of all the testtags?
I also see I dont have any tags like $avgmonthsnow1 to go with in my test of Dashboard 6.07
Thank you.
« Last Edit: January 31, 2011, 02:18:49 PM by CNYWeather »
Tony
Offline jgillett
« Reply #218 on: January 31, 2011, 02:21:30 PM »
Hi Scott,
Scott
No rush - just wondering.
Is it just basically replacing split with explode, or am I making it too easy?
W7JKG
« Reply #219 on: January 31, 2011, 09:15:08 PM »
Hi Scott,
Scott
LOL, Easy is always good... I have been starting the upgrade for awhiel, just no time to put into it right now!
Scott
« Reply #220 on: January 31, 2011, 09:17:39 PM »
Thank you.
$avgmonthsnow1 and $avgmonthrain1 are variables from the script itself, not test tags.  The base testtags.txt are available from Ken's site if I remember and then the additional tags are available in a text file in the script archive. (version 6.xx)
Scott
Offline jgillett
« Reply #221 on: January 31, 2011, 10:35:36 PM »
Hi Scott,
Scott
Scott
Drop me an email with a split statement and what it would look like translated for 5.3. Maybe I can fiddle with it.
The class I told you about starts Wednesday. Cross fingers (eyes, toes, etc.) please...
W7JKG
Offline klamort
« Reply #222 on: February 01, 2011, 12:30:03 AM »
Klaus,
Scott
Hi Scott,
I did certainly change all the metrics I found.... so I did set up again the original files... but I am still having the same problem...
KLaus
« Reply #223 on: February 01, 2011, 08:31:04 AM »
There is no need to change the code for that, just change the default unit of measure in the settings to "M" and it will do that automatically.  Send me a copy of your ajax-dashboard6.php and I'll check it out.
Scott
Offline stormwatch
    • Carolina StormWatch Weather
« Reply #224 on: February 02, 2011, 03:29:36 PM »
Hope someone can help me pinpoint the problem that is keeping me from successfully updating from Scott's V4.20 to the new ajax V6.07. I have been working off and on with this for several months (ajax) but have tried to get down to serious business the last week and just can't get the dashboard to show on my test page. All I am getting is the top, head and fly=out menu. No dashboard or footer. Not too familiar with Firebug but had it up and working and could see my clientraw info getting pulled in alright. ](*,)
Here is what I am getting right now:  www.carolinastormwatch.com/indextest.php
Also attached my Dashboard6 file and ajaxWDwx and ajaxWDwx-settings files if  someone could please take a look and see if they can spot a problem.
Any help would be greatly appreciated!! Tony at CNY Weather has been very helpful but he has had trouble locating the issue.
Tom
CoCoRaHS NC-BR-1
CW0803
Advanced Spotter
