Someone that was visiting my site and noticed a problem that I was having with my ajax updates and brought it to my attention. When you go to my homepage:
www.carolinastormwatch.com/ the page will update as it should but then after that the time flashes green every 5-10 seconds as it should but the info on the dashboard is not updating and the it is not resetting the update time; the page continues on and does not refresh unless you manually refresh the page.
I have no idea when this began and how long it has been going on but it had been working fine previously. I am thinking that this issue began when I updated my testtags which was causing an issue because I was missing some tags. Probably a coincidence and not sure this was the time problem developed.
I am running Version 6.10 of Scott's Dashboard. Anyone have any ideas of what may be going on here??? Any suggestions would be appreciated! Wonderful job that you have done building this script Scott; I know this all has been a pain in the a#@ at times but we certainly appreciate your great work!!
Tom
