Author Topic: Alternative-Dashboard Version 6.21  (Read 151284 times)
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
Re: Alternative-Dashboard Version 6.20
« Reply #525 on: July 09, 2011, 06:54:38 PM »
LOL, yes, but back home a day early and already getting put to work by friends!    :shock:   I should have stayed on vacation!
Ah - sorry.
BTW - aren't you still on vacation??
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #526 on: July 09, 2011, 10:55:56 PM »
Well, hope you had a good time while it lasted!
W7JKG
Offline WraxallDave
« Reply #527 on: July 10, 2011, 10:33:17 AM »
Hi John,
see http://www.wxforum.net/index.php?topic=9538.msg112072#msg112072
and you will see how the wind icons disappear.
Ken's original does it right this one screws them up.
Dave.
« Reply #528 on: July 10, 2011, 10:36:12 AM »
What version of ajaxWDwx.js are you using with both?
Scott
Hi Scott,
I have installed version 6.20 with the language option, but it has not fixed the wind direction icons from being lost.
Take a look  http://www.wraxall-weather.co.uk/index.php
Did you look at this problem when changing the language selector.
Dave
Offline WraxallDave
« Reply #529 on: July 10, 2011, 10:48:56 AM »
Hi Scott,
I installed the ajaxWdwx.js that came with the 6.20 download.
var ajaxVersion  = "3.04a";
var ajaxVersDate = "22-Jan-2011"; /* Release date
Dave
« Last Edit: July 10, 2011, 10:52:23 AM by WraxallDave »
« Reply #530 on: July 10, 2011, 10:54:35 AM »
So you are using the same file with both the working version and the non-working version of the code?
Scott
Hi Scott,
Dave
Offline WraxallDave
« Reply #531 on: July 10, 2011, 11:09:42 AM »
Hi Scott,
For Ken's version I renamed his ajaxWDwx to ajaxWD1wx
// --- Version 2.21 - 17-Feb-2011 -- added decimal comma option for international display
Dave.
« Reply #532 on: July 10, 2011, 11:18:20 AM »
Ok, that was what I was wondering, if it still works with version 3.04a or not.
Hi Scott,
Dave.
Offline jgillett
« Reply #533 on: July 10, 2011, 04:38:55 PM »
Hi John,
Dave.
Hi Dave,
Went back to your site and saw the wind icon in place. Changed to Spanish. The wind icon was still there, but the page had completely lost contact with the CSS. A huge mess. This happened more than once.
Just FYI...
W7JKG
Offline WraxallDave
« Reply #534 on: July 11, 2011, 06:13:23 AM »
John,
It seems to get out of that problem you set the "Style" option and press "Set" and it goes away. But why it does that in the first place I do not know.
Another problem is with the forecast section, the German translation can be very large at times and causes the section to expand off the page and mess up the screen. As you can see the Alternate-Dashboard has many serious problems with the language selection option.
Dave.
Offline jgillett
« Reply #535 on: July 11, 2011, 02:07:39 PM »
Hi Dave,
Obviously I can certainly understand the need for the language options. In my case I just stay with English - less hassle.
As for why that is happening - afraid I can offer no help. Sorry.
W7JKG
Offline jgillett
« Reply #536 on: July 15, 2011, 03:44:59 PM »
This seems to be the day for problems.
The solar icon is currently not showing on my main page. Source shows it's looking for...
<img src="ajax-images/SI79 %.gif" height="65" width="34" alt="" title="Current Solar Index" />
...which I understand it not finding.
It's been working great up to now. Haven't touched anything - honest!
W7JKG
Offline WraxallDave
« Reply #537 on: July 16, 2011, 10:24:41 AM »
Hi John,
I have the Solar icon problem from time to time, the function that creates the SI icon name get_SIrange($currentsolarpercent)
screws up and produces the wrong icon names.
Dave
« Reply #538 on: July 16, 2011, 11:21:16 AM »
Yes, I have been looking at that solar icon issue also, it seems that sometimes the value sent by WD is not a number so it fails to give the proper reading.. I may have to add an icon for N/A or something for those times.
Scott
Offline jgillett
« Reply #539 on: July 16, 2011, 11:40:07 AM »
Trying to understand this - why wouldn't it fail on the mobile dash at the same time? Don't the two programs get their data from the same place?
W7JKG
Offline tnwxman
  • KK4QXH
    • Weather for Lebanon, TN 37087
« Reply #540 on: July 16, 2011, 03:01:02 PM »
Hi All,
Need some help. When I click on the home option on the flyout menu I get the following:
Parse error: syntax error, unexpected '<' in /homepages/6/d330860172/htdocs/wxindex.php on line 51
Line 51 in wxindex.php is:
<div id="main-copy">
What is causing this?
Bob
Bob
KK4QXH
Offline CNYWeather
    • CNYWeather
« Reply #541 on: July 16, 2011, 03:10:13 PM »
Clicking on your banner brings you to index.php
Maybe change the link in flyout menu to reflect that?
Tony
« Reply #542 on: July 16, 2011, 04:01:03 PM »
yes, but not at exactly the same time, it only happens every once inawhile
Offline tnwxman
  • KK4QXH
« Reply #543 on: July 16, 2011, 04:28:04 PM »
Hi Tony,
That fixed it. Thanks.
Bob
Bob
KK4QXH
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #544 on: July 26, 2011, 02:07:59 AM »
Hi Scott,
I don't know if this is just my problem but whenever the UV index in the prediction mode goes over 12.5 or more the UV icon is not displayed.  Also, during the day when it goes over that 12.5 threshold the icon is not displayed for some reason. Sometimes I get a UV index that approaches 15 when the sun is near vertical at my location.  This happens BTW twice a year being in the tropics.  It is called the Lahaina Noon over here. See the attached snapshot from this evening. I am currently using version 6.20.
Thanks for you comment or possible solution.
--Stan Y.
   Maui, Hawaii
« Last Edit: July 26, 2011, 02:17:19 AM by Silversword »
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
« Reply #545 on: July 26, 2011, 07:41:21 AM »
I will have to add in some code to handle that.  I didn't think there was supposed to be anything over 11 so I didn't put anything in there to handle that.
Scott
Hi Scott,
--Stan Y.
   Maui, Hawaii
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #546 on: July 26, 2011, 12:29:58 PM »
Scott
Scott,
The Solar Icon issue could be complicated by a programming issue.  I don't think it's a good idea to pass a value to a routine, manipulate the value in a routine, and then pass it back to the caller all the while using the same variable name.  This routine, 'get_SIrange', is used in both Alternative-Dashboard Version 6.20 and WWL-mobile mobile dashboard.  If you look at it you will see that it is called with the parameter '$currentsolarpercent' by the calling routine, but '$si' is used as the data passed to it, which then is manipulated by the routine and returned as '$si'.  I've changed the routine to use a strictly local parameter as follows:
function get_SIrange ( $solarpercent ) {
   switch (TRUE) {
     case ($solarpercent == 0):
       $si = '0';
     break;
     case (($solarpercent > 0) and ($solarpercent < 10)):
       $si = '0';
     break;
     case (($solarpercent >= 10) and ($solarpercent < 19)):
       $si = '1';
     break;
     case (($solarpercent >= 20) and ($solarpercent < 29)):
       $si = '2';
     break;
     case (($solarpercent >= 30) and ($solarpercent < 39)):
       $si = '3';
     break;
     case (($solarpercent >= 40) and ($solarpercent < 49)):
       $si = '4';
     break;
     case (($solarpercent >= 50) and ($solarpercent < 59)):
       $si = '5';
     break;
     case (($solarpercent >= 60) and ($solarpercent < 69)):
       $si = '6';
     break;
     case (($solarpercent >= 70) and ($solarpercent < 79)):
       $si = '7';
     break;
     case (($solarpercent >= 80) and ($solarpercenti < 89)):
       $si = '8';
     break;
     case (($solarpercent >= 90) and ($solarpercent < 99)):
       $si = '9';
     break;
     case ($solarpercent >= 100):
       $si = '10';
     break;
   } // end switch
   return $si;
} // end get_Solarrange
This may or may not have anything to do with the red 'x' showing up at times instead of the Solar Index icon.  I'm not seeing it with my modified Ajax-Dashboard6 or my modified mobile dashboard, for whatever it's worth.
Regards, Jerry Wilkins
gwwilk@gmail.com
« Reply #547 on: July 26, 2011, 07:23:34 PM »
I'll check that out, see if it helps!  From what I've seen though, it is actually coming from WD.
Scott
Scott
Scott,
   switch (TRUE) {
       $si = '0';
     break;
       $si = '0';
     break;
       $si = '1';
     break;
       $si = '2';
     break;
       $si = '3';
     break;
       $si = '4';
     break;
       $si = '5';
     break;
       $si = '6';
     break;
       $si = '7';
     break;
       $si = '8';
     break;
       $si = '9';
     break;
       $si = '10';
     break;
   } // end switch
   return $si;
« Reply #548 on: July 26, 2011, 07:40:19 PM »
I have a fix for the UV over 11 issue.  Need someone with the problem to check it for me.  Please email me if you can test it.
Scott
Hi Scott,
--Stan Y.
   Maui, Hawaii
Offline stormwatch
    • Carolina StormWatch Weather
« Reply #549 on: July 26, 2011, 08:27:33 PM »
Someone that was visiting my site and noticed a problem that I was having with my ajax updates and brought it to my attention. When you go to my homepage: www.carolinastormwatch.com/ the page will update as it should but then after that the time flashes green every 5-10 seconds as it should but the info on the dashboard is not updating and the it is not resetting the update time; the page continues on and does not refresh unless you manually refresh the page.
I have no idea when this began and how long it has been going on but it had been working fine previously. I am thinking that this issue began when I updated my testtags which was causing an issue because I was missing some tags. Probably a coincidence and not sure this was the time problem developed.
I am running Version 6.10 of Scott's Dashboard. Anyone have any ideas of what may be going on here??? Any suggestions would be appreciated! Wonderful job that you have done building this script Scott; I know this all has been a pain in the a#@ at times but we certainly appreciate your great work!!
Tom
CoCoRaHS NC-BR-1
CW0803
Advanced Spotter
