Note: trouble with registration? See this for more info.
Hi, Scott,If i shut the java engine down in FF then it gives the right CC-icon, so i think it must have to do something with the ajaxWdwx.js or is this wrong?Thanks for the help so far!Staccermaccer.
$useSTAhilo = true; // Set to True for Station High/Low (Must have 2 years data to use) or False for WU High/Low
Hello,I upgraded to the latest v of WD. Now my web page keeps showing New Record High. I believe this has to do with WD as 6.10 was working fine before. Any suggestions.Another questions is there a way to show the heat index or wind chill (either shows based on threshold set) under the Currently outside temperature. The NWS uses heat index and windchill and not feels like. I would like those indexes to show instead of feels like in that place on the web page. Please advise.http://lebanontnwx.orgThanks,Bob
<?php langtrans('Feels like'); ?>: <span class="ajax" id="ajaxfeelslike"> <?php echo strip_units($feelslike) . $uomTemp; ?>
<?php langtrans('Heat Index'); ?>: <span class="ajax" id="ajaxheati"> <?php echo strip_units($heati) . $uomTemp; ?>
Hi Scott,Thank you I will make the change to false for the high and low. Yes, I would like to make the change with the feels like temperature, how would I do that and what code would I replace with what code?Thanks,Bob
Hi Scott,Thank you. I did as suggested. The heat index shows when the page loads but when the descrpitive word appears the value changes to the feels like temperature. In this heat index is 91 but the feels like is 104. So it works momentarily then as mentioned when the descriptive word appears it shows the fees like. Must be another place in the script that needs changing also. Please advise.Also you mentioned windchill is this a new line to add or where is it found.Thanks,Bob
<span class="ajax" id="ajaxheatcolorword"><?php echo $heatcolourword; ?></span><br/>
Hi Scott,Here is the code. I beleive I have it correct. Results are it shows until the descriptive word appears then it goes to a much higher reading which is commomly the feels like temperature. <?php langtrans('Heat Index'); ?>: <span class="ajax" id="ajaxheati"> <?php echo strip_units($heati) . $uomTemp; ?>Please advise. Thanks.Bob
Hi Scott,I did as instructed (removed the wording line) and that did not work. Instead of showing a Feels like temperature of 107 and extremely hot it is showing 107 feels like and now the descriptive word is warm. The descriptive word is not the issue. I would like the descriptive word to continue to show. The problem is the Heat index in WD, WL and on the webpage say it is 97or 96. The value on the web page under the current temperature shows a 'feels like' of 107 n o the heat index of 96 or 97. The heat index never made it to 107 today so it cannot be showing the high heat index as that was 103. So the issue is I made the changes and instead of the heat index showing in place of the feels like temperature it appears I am still getting the feels like temperature and now with the wrong descriptive word. Any ideas? I appreciate your patience and help.Best regards,Bob
I've got an "UV Summary/Forecast" error in today's forecast of 11.5; however the code want's to display a UV12.gif (that I don't have). I've seen this a few times over the last several weeks. Where can I get a UV12.gif from?
Quick fix will be to make a copy of the UV11.JPG and call it UV12.The rounding issue is rounding up the 11.5 to 12.
Quote from: mayo9999 on June 21, 2011, 01:13:31 PMI've got an "UV Summary/Forecast" error in today's forecast of 11.5; however the code want's to display a UV12.gif (that I don't have). I've seen this a few times over the last several weeks. Where can I get a UV12.gif from?Had the same problem here. From Scott...QuoteQuick fix will be to make a copy of the UV11.JPG and call it UV12.The rounding issue is rounding up the 11.5 to 12.Yes, you will still see the 11+ graphic (there is no UV12 graphic at this time), but at least it won't be blank or throw an error.
Hi Scott,Should I include it as an attachment or can I e-mail it to you. Please advise.Bob
For now, that is going to be the official fix for this as there is no UV12 (it only goes to 11+ officially) and it's a rounding error. I will add an icon for 12 that will just read 11+ too.ScottQuote from: jgillett on June 21, 2011, 01:53:16 PMQuote from: mayo9999 on June 21, 2011, 01:13:31 PMI've got an "UV Summary/Forecast" error in today's forecast of 11.5; however the code want's to display a UV12.gif (that I don't have). I've seen this a few times over the last several weeks. Where can I get a UV12.gif from?Had the same problem here. From Scott...QuoteQuick fix will be to make a copy of the UV11.JPG and call it UV12.The rounding issue is rounding up the 11.5 to 12.Yes, you will still see the 11+ graphic (there is no UV12 graphic at this time), but at least it won't be blank or throw an error.
File attached.
Hi Scott,Thank you for looking into this. Ok so what might I have running that would cause this? I still have my original ajax-dashboard file in the same directory could that be the cause. If not what might I have different somewhere else that is causing this? You can see from my website what I am getting and I see your results. I am new to php etc. so I have been following the lead I get from you and others. When I had the orginal dashboard Ken gave me code to use the heat index and windchill instead of feels like. If the current setup still use the orginal in addition to 6 could that be the issue? Please advise.Bob
Hi Scott,That was it. Index.php was not calling 6. Sucess. Anyway to get the wording back and still have the heat index show. Also is there a way to have the wind chill show when there is a wind chill temeprature. I know you said I would have to make a manul change but if it could be automated that would be great. Let me know.Agin many thanks for your help (putting up with newbies). This is a great script keep up the good work!!!Best regards,Bob
