As the title of this post says, I have a problem.
Although my home built, PVC monstrosity worked perfectly I have not been able to get it out of my head that I spent $35.00 on a SR-100 (that I'm not using) and have this ugly thing hanging on the side of my garage.
Well the result of these mental ponderings is that I once again re-thought my shield design.
Here's what I did.......
I used the SR100 as the base for this new FARS...
Picture the SR100 with a 6-1/4" long piece of 2" PVC pipe running vertically, straight through the middle of the shield.
I cut out an opening on the second solid plate and on the next to the bottom solid plate for the piece of pipe to fit into.
I also cut an 1-1/2" hole in the very bottom plate of the shield and mounted my PC power supply fan directly onto the bottom of the SR100.
The top of the 2" PVC pipe is exactly in the middle of the top and second plates of the shield.
The bottom of the 2" PVC pipe is butted up against the fan with the bottom plate between the pipe and the fan.
I ran 4 drywall screws into the PVC pipe (at the very bottom) to create a base for my sensor to sit on. I also took one of the circles that were cut out of the SR100 and drilled as many holes as possible into it.
The drilled circle was then ground down to slide into the 2" PVC pipe to give a non-abrasive surface for the shield to sit on. The drilled circle sits on the drywall screws and the sensor sits on the drilled circle.
What this setup allows is for air to be drawn into the top of the 2" PVC pipe and past the sensor inside.
The air is exhausted out of the bottom via the fan.
It should work exactly as the other monstrosity that I built but the setup looks a lot more appealing and I'm using the SR100 that I paid hard earned money for.
Looking at the SR100 you cannot tell that it is not stock but this should provide complete protection from solar heating.
The next thing I need to design is a solar panel/battery backup system so that I can stop using the 120 volt to 12 volt converter that I've been using.
If anyone sees any problems with this design, let me know, but all in all I'm pretty happy with how it has worked out so far.
By the way....I used a Rotozip to cut the holes in the SR100 but I'm sure that a dremel or similar device would work just as well.
If anyone needs to see pics of what I've done, let me know, but please.......only if necessary. I've had that SR100 apart so many times that just the thought of taking it back apart makes me cringe.
Even thought I wasted a little money on the PVC monstrosity, it gave me the idea to re-work the SR100. We'll just call that: Money well spent on R&D
Dave
