Author Topic: Weather Underground and aditional sensor for meteo station  (Read 934 times)
Offline machal1428
« on: September 13, 2023, 08:32:52 AM »
Hey all,
I woud like to buy this meteo station - https://www.weerstationkopen.nl/weerstations/garni/garni-1025-arcus
This station has 7in1 sensor, so it is impossible split the temp sensor from the rainfall/wind sensor...
But there is a possibility buy a aditional temp sensor.
My question is. It is possible say to Wunderground - use the temp data only from the aditional sensor ? For example. The main temp sensor is on channel 1, and the aditional temp sensor is on chanel 5 , so its possible to use only channels 2,3,4 and 5 for Wunderground ?
Thanks a lot ! :)
Offline machal1428
Re: Weather Underground and aditional sensor for meteo station
« Reply #1 on: September 26, 2023, 02:00:50 AM »
Ok, I will reply myself. It can be used sensor WH32 (ecowitt) https://shop.ecowitt.com/products/wh32-outdoor
This sensor fully replaced temp and humidity from the main sensor.
Offline gianvi97
« Reply #2 on: October 14, 2023, 12:51:51 PM »
Hi, so how do you send the data from that additional sensor to wunderground?
Offline machal1428
« Reply #3 on: October 14, 2023, 01:01:35 PM »
Not from adfitional, I sending data from the WH32. WH32 sensor fully replace the main temp and humidity sensor..
