Simple Javascript to get just PM2.5 value from PurpleAir json, need help.
(1/1)
bthoven:
I have a webpage displaying all my weather information and I would like to add nearby PurpleAir station data to my webpage. I've tried this script to get Json data, but I can't get the value from it. Need help...thanks.
<!DOCTYPE html>
<html lang="en">
<head>
<title>JavaScript - read JSON from URL</title>
<script src="https://code.jquery.com/jquery-3.2.1.min.js"></script>
</head>
<body>
<div class="mypanel"></div>
<script>
$.getJSON('https://www.purpleair.com/json?show=26581', function(ppa) {
var ppa1 = `PM2.5: ${ppa.results.PM2_5Value}<br>
Time: ${ppa.results.LastUpdateCheck}<br>
Data: ${ppa}`
$(".mypanel").html(ppa1);
</script>
</body>
</html>
The result I got is:
PM2.5: undefined
Time: undefined
Data: [object Object]
The url itself in browser got the json data:
{"mapVersion":"0.4","baseVersion":"7","mapVersionString":"","results":[{"ID":26581,"Label":"Sansiri - Habito T77","DEVICE_LOCATIONTYPE":"outside","THINGSPEAK_PRIMARY_ID":"702607","THINGSPEAK_PRIMARY_ID_READ_KEY":"31QAMK9TLHF2CPH4","THINGSPEAK_SECONDARY_ID":"702608","THINGSPEAK_SECONDARY_ID_READ_KEY":"JS8H3KOAP717ZY4H","Lat":13.712708,"Lon":100.600961,"PM2_5Value":"51.69","LastSeen":1578814563,"Type":"PMS5003+PMS5003+BME280","Hidden":"false","DEVICE_BRIGHTNESS":"15","DEVICE_HARDWAREDISCOVERED":"2.0+BME280+PMSX003-B+PMSX003-A","Version":"4.11","LastUpdateCheck":1578814470,"Created":1550077244,"Uptime":"121","RSSI":"-71","Adc":"nan","p_0_3_um":"8375.65","p_0_5_um":"2552.84","p_1_0_um":"480.53","p_2_5_um":"27.39","p_5_0_um":"4.71","p_10_0_um":"2.27","pm1_0_cf_1":"50.08","pm2_5_cf_1":"76.57","pm10_0_cf_1":"81.22","pm1_0_atm":"33.82","pm2_5_atm":"51.69","pm10_0_atm":"64.78","isOwner":0,"humidity":"44","temp_f":"95","pressure":"1005.91","AGE":3,"Stats":"{\"v\":51.69,\"v1\":53.67,\"v2\":55.14,\"v3\":55.11,\"v4\":59.34,\"v5\":65.78,\"v6\":48.17,\"pm\":51.69,\"lastModified\":1578814563332,\"timeSinceModified\":1369401}"},{"ID":26582,"ParentID":26581,"Label":"Sansiri - Habito T77 B","THINGSPEAK_PRIMARY_ID":"702609","THINGSPEAK_PRIMARY_ID_READ_KEY":"EZVKAJ8HSLOFET6A","THINGSPEAK_SECONDARY_ID":"702610","THINGSPEAK_SECONDARY_ID_READ_KEY":"Y5JSFB4S22LUGTPW","Lat":13.712708,"Lon":100.600961,"PM2_5Value":"50.0","LastSeen":1578814563,"Hidden":"false","Created":1550077244,"Adc":"0.05","p_0_3_um":"8126.86","p_0_5_um":"2464.0","p_1_0_um":"414.39","p_2_5_um":"34.59","p_5_0_um":"5.16","p_10_0_um":"0.91","pm1_0_cf_1":"50.16","pm2_5_cf_1":"71.93","pm10_0_cf_1":"76.48","pm1_0_atm":"33.8","pm2_5_atm":"50.0","pm10_0_atm":"62.52","isOwner":0,"AGE":3,"Stats":"{\"v\":50.0,\"v1\":52.85,\"v2\":54.58,\"v3\":54.64,\"v4\":58.61,\"v5\":64.75,\"v6\":47.58,\"pm\":50.0,\"lastModified\":1578814563332,\"timeSinceModified\":1369401}"}]}
droiddk:
What do need from the JSON data?
You have errors in your script, maybe this example can help:
--- Code: --- <script>
$.getJSON('https://www.purpleair.com/json?show=26581', function(data) {
var lastUpdateCheck = data['results'][0]['LastUpdateCheck'])
$("#containerForLastUpdateCheck").html(lastUpdateCheck);
</script>
--- End code ---
Edit above to your own needs.
Regards
wvdkuil:
--- Quote from: bthoven on January 12, 2020, 07:02:56 AM ---. . . shortened . . .
--- Code: --- <div class="mypanel"></div>
<script>
Data: ${ppa}`
</script>
--- End code ---
PM2.5: undefined
Time: undefined
--- End quote ---
The results is an array.
Add a pointer to the correct element
<script>
var ppa1 = `PM2.5: ${ppa.results[0].PM2_5Value}<br>
Time: ${ppa.results[0].LastUpdateCheck}<br>
Data: ${ppa}`
</script>
--- End code ---
and it will display correctly
--- Code: ---PM2.5: 46.21
Time: 1578829758
--- End code ---
bthoven:
Thank you very much. I got it now. [tup]
๋ี๋๋Just to share the script.
--- Code: ---getPPA();
function getPPA()
var pm25now = ppa.results[0].PM2_5Value;
//$('#pm25now').attr("value",pm25now);
$('#pm25now').text(Math.round(pm25now));
var lastseen = ppa.results[0].LastSeen;
// Create a new JavaScript Date object based on the timestamp
// multiplied by 1000 so that the argument is in milliseconds, not seconds.
var datep = new Date(lastseen * 1000);
// Hours part from the timestamp
var hours_p = datep.getHours();
// Minutes part from the timestamp
var minutes_p = "0" + datep.getMinutes();
// Seconds part from the timestamp
var seconds_p = "0" + datep.getSeconds();
// Will display time in 10:30:23 format
var formattedTime = hours_p + ':' + minutes_p.substr(-2) + ':' + seconds_p.substr(-2);
// Will display time in 10:30 format
var lastseen = hours_p + ':' + minutes_p.substr(-2);
$('#lastseen').attr("value",lastseen)
setTimeout(getPPA, 60000); // set auto refresh every 60s (working, except ie)
--- End code ---
