Brian,
Latest version looks great. I'll drop you an email about how to adapt the code to my application if I get a chance to work on it between now and your next update. Looking forward to the changes you have coming!
--edit-- I noticed my charts don't work if I select USA (I'm in the USA) but work fine if I select North America.
Matt
GOOD MORNING
i addressed some things this morning particularly non metric you can simply try the fix(es) with the
http://www.mediafire.com/file/sw0ry9222nhlvvp/COMMUNITYUPGRADE.zipsimply replace settings.php and chartswu folder
i tested this weather output in non metric from
http://ws.nyweather.net/test files so hopefully it solve the issues .
StatenIslandWeather try the upgrade zip i could see you were only having an issue with temperature charts which i change the conversion script in temperatures i couldnt see any other issues in other charts on your test site .
mattwx application ? enlighten us.
next full release wont be until November probably late November due to mixture of home DIY and decorating with replacing one of our bathrooms , saved ourselves $1200 by doing it myself which seemed a good idea at the time, so if I don't get the bathroom done my wife will hang me by the balls from the ceiling .
so hang in there ..brian
