I mentioned this in another thread, but I thought I should add some clarifications and cautions.
I have a small fridge in the garage, that has a flaky thermostat.
So using a t/h sensor and the AC1100 I have done the following
1. set the fridge thermostat to max
2. Programmed the AC1100 smart switch to turn on the fridge if the temp is > 38F, and off if temp is <36F with 2 triggers
The Pros on this, depending on fridge is that most fridges use a mechanical thermostat , which may have large swings in temperature. Using the temp sensor and switch in this case, can allow you to fine tune the temperature and figure out a reasonable hysteresis and be more accurate on the actual fridge temp.
Cons: You are essentially making the fridge operate or not, so if you have things like fridge lights, they won't work when the switch is off. Also , you are bypassing the actual function of designed fridge. I would not do this on a modern fridge with advanced controls or ice maker, water dispenser, etc.
I have no idea really on how this will effect the compressor of the unit
So, in the end proceed at your own risk. I'm doing this with a small fridge (think like a 4.9 cu ft dorm, or etc ) in my garage where the mechanical thermostat can no longer be adjusted to meet my needs, it is 25 years old, and I am go to replace it. This was done as test. Actually, as I see this works, I could have held off on ordering a new fridge and run the old one till it died, but I need the fridge, so I had ordered a new one, before this test.
