Author Topic: Meteostick reception mystery  (Read 349 times)
Offline hmderek
    • Meteodrenthe
« on: April 30, 2020, 07:24:13 AM »
I use a Meteostick to receive data from my Davis VP2. I log everything it receives in the process. I've got a setup with 2 6332OV transmitters. One it set to id 1, the other to id 2.
However, the Meteostick usually receives data from id 1 at expected intervals, but only intermittent from id 2.
Now I confirm with my Davis console using diagnostic mode that id 2 is transmitting at the expected intervals. I can see the number of updates it receives from id 2. I do notice that it takes longer to connect to id 2 than to id 1 for the console, but once it does all seems well.
I am aware of the fact that the reception of the Meteostick is not nearly as good as the Davis console. However, when I do receive data from id 2, signal strength is good. (-55 to -58) I've positioned both the Meteostick and the transmitter with no obstacles in between.
Additionally, I have 2 other transmitters I do not use at the moment, but when I test those, I get pretty much the same as with id 2. Only infrequent updates, while id 1 keeps transmitting. It does not matter which id is set, everything except id 1 does not work properly.
Does anyone have a clue how to explain this behavior?
« Last Edit: April 30, 2020, 07:27:29 AM by hmderek »
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Apogee Instruments TS-100
Barani Meteoshield Pro
Davis 7714
MetSpec RAD14
Davis AirLink
Wemos D1 Mini micro controllers
https://blog.meteodrenthe.nl
https://meteodrenthe.nl
https://twitter.com/meteodrenthe
Offline hmderek
    • Meteodrenthe
Re: Meteostick reception mystery
« Reply #1 on: May 01, 2020, 11:09:15 AM »
Update:
I've been trying some things. I had the transmitter id filter set to receive data from all 8 id's. I now have it limited to 1 and 2, and it seems that has a positive effect on the number of id 2 updates it receives. This seems unexpected.
I also notice that even though I only accept id 1 and 2, ids from my transmitter with id 7 still get through at times. When I instruct the Meteostick to receive ids 1, 2 and 7, the frequency of id 7 updates increases too.
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Davis 7714
MetSpec RAD14
Davis AirLink
