Author Topic: NOAA WEATHER RADIO  (Read 160650 times)
Offline ValentineWeather
Re: NOAA WEATHER RADIO
« Reply #375 on: March 26, 2017, 11:56:38 AM »
Thanks much, had me scratching my head..Now to add a link for website.
Randy
Offline satcop
    • Clifton Virginia Weather
« Reply #376 on: March 26, 2017, 12:01:59 PM »
  Glad you got another one up!
Thanks, if you could provide the info to this page if would help us putting this thing together greatly.
http://noaaweatherradio.org/addstream/addstream.html
Bob
Clifton, Virginia Weather
Blitzortung Stations 1189, 1451 - CWOP EW1675
« Reply #377 on: March 26, 2017, 12:17:51 PM »
Bob
Filled out and submitted.
Randy
Offline Cutty Sark Sailor
  • Moderator
« Reply #378 on: March 26, 2017, 12:25:15 PM »
Bob
And you're live on the stream player!
Mike
« Reply #379 on: March 26, 2017, 12:35:04 PM »
 8-) cool. I'll probably add your webpage later.
Randy
« Reply #380 on: March 26, 2017, 12:56:33 PM »
Bob
Bob I embedded stream link on my website. Not sure if this needs changed on signup page.  http://www.valentinenebraska.net/radio.php
Randy
Offline satcop
« Reply #381 on: March 26, 2017, 01:02:21 PM »
You need a player on the page to make it work, I see you are using a Saratoga script, if you just want to run your feed use this file: here .  You will see the stuff you need to change near the top of the file, you should be up and running in very short order.
« Reply #382 on: March 26, 2017, 01:57:27 PM »
Thanks, it was working with chrome and even IE but not with phone so changed over. Appreciate it, very nice.  =D>
« Last Edit: March 26, 2017, 02:09:15 PM by ValentineWeather »
Randy
  • Moderator
« Reply #383 on: March 26, 2017, 03:33:33 PM »
When things shake out a bit, we'll probably post script packs on the NWEORG site...
they're changing so quickly right now, here's the best place to grab updates...I suppose....
...meantime, here's the single player code I use on my pages for my local WxRadio stream
code page w/example audio ---attached---
Cheers!
Mike
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #384 on: March 26, 2017, 08:44:37 PM »
First real test for my area and proof what we are doing here matters.   :grin:  This was a result of tornado warnings issued the neighboring county to my NW.
Each one of these listeners could have a family, employees, the list is endless, under their wing that would be less safe if they were unable to hear the local weather warnings and forecast via our radio streams.
« Last Edit: March 26, 2017, 08:48:53 PM by Mark / Ohio »
  • Moderator
« Reply #385 on: March 26, 2017, 11:08:04 PM »
Lemme see... just approximately.... Wx radio. $40. Audio Cable $3. Software Free? Computer you already had.
So, if a listener was worth $0.50, you paid for hardware, with a bit left over for operating expenses. Over a few hours period...
97 affected Lives / families / businesses etc???? ...  Priceless.  ...
Yep... thought about throwing a slogan up for several weeks... something like
"Maybe Save A Life"
You deserve a Gold Star, Mark.
Offline Jumpin Joe
    • Joe’s Weather
« Reply #386 on: March 27, 2017, 10:43:10 AM »
NOAA Radio on my site is not broadcasting... says "Loading".
Looking at m3w appears all is well.
Any thoughts?
Joe
https://joesweather.info
WeatherLink Live
Offline 92merc
  • BismarckWeather.net
  • Moderator
« Reply #387 on: March 27, 2017, 10:54:03 AM »
Personally, when I'm in doubt, I look at this webpage to see if my stream is on there.  If not, then they aren't receiving you.  You'll probably need to restart your software.
http://wxradio.dyndns.org:8000/
Offline Jumpin Joe
    • Joe’s Weather
« Reply #388 on: March 27, 2017, 11:00:15 AM »
Tried restarting before I posted. Did not correct it.
WeatherLink Live
Offline codegod
  • Software Developer
    • Crushed Box Software
« Reply #389 on: March 27, 2017, 11:03:49 AM »
Hey Joe this is Chris from Crushed Box Software owner/operator of the wxradio.dyndns.org icecast server. Which feed are you providing?
« Reply #390 on: March 27, 2017, 11:06:30 AM »
Try to record short output file locally, play back and see if you get anything.
Also on my program if I closed and reopened everything in settings goes back to default so had to re-enter.
Randy
Offline Jumpin Joe
    • Joe’s Weather
« Reply #391 on: March 27, 2017, 11:34:16 AM »
Covington,KY KIH42
WeatherLink Live
Offline Jumpin Joe
    • Joe’s Weather
« Reply #392 on: March 27, 2017, 11:45:29 AM »
Just discovered the samething.... why arent the settings saved?
WeatherLink Live
« Reply #393 on: March 27, 2017, 11:56:24 AM »
Not sure, I was thinking after initial save you may need to grab the saved file every time you reopen. Haven't tried it yet.
Randy
Offline Jumpin Joe
    • Joe’s Weather
« Reply #394 on: March 27, 2017, 12:02:45 PM »
I saved some screens shots of my settings this time so I won't have to tax the ole gray matter again.... I hope.  Hopefully they'll get me back up soon.
WeatherLink Live
Offline 92merc
  • Moderator
« Reply #395 on: March 27, 2017, 12:03:22 PM »
Are you running Windows 10?  If so, try opening the program by right clicking and choose "Run as Administrator".  Without admin rights, it may not keep the settings where you want.
Offline Jumpin Joe
    • Joe’s Weather
« Reply #396 on: March 27, 2017, 12:16:44 PM »
Thanks!  I did'nt know that.
WeatherLink Live
Offline floodcaster
    • Goose Lake Weather
« Reply #397 on: March 27, 2017, 12:18:14 PM »
Same issue here. In my M3W dir I had a config file with "nwr name".m3w and a default file. I renamed the "nwrname".m3w to default and now loads with my settings. This is just a workaround as you'd have to do this whenever you made a change. There must be something I'm missing.
Bill
Offline W3DRM
    • Emmett Weather
« Reply #398 on: March 27, 2017, 01:25:11 PM »
Okay, I see there is already a feed for the Reno, NV area so I'm not going to try to get a duplicate station feed running myself.
However, I am attempting to get the template running as described by SATCOP - Bob, in reply #367 of this thread. I can get it running nicely after making the changes but I cannot get it to fire-off the audio stream automatically. I have to select another station and then go back to my default (selected) station for it to begin the broadcast. I'm obviously missing something but can't for the life of me figure out what it is. BTW, if I simply go back to the original code downloaded, the default station starts up without any manual intervention.
EDIT: I am running the following version of the code:
  • wxnoaaradio.php - Version 170322
  • wxnoaaradio-select.php - Version 170326B
  • inc-wxnoaaradio.php - Version 170326B
« Last Edit: March 27, 2017, 01:31:48 PM by W3DRM »
Don - W3DRM - Emmett, Idaho --- Blitzortung ID: 808 (temporarily off-line) --- FlightRadar24 ID: F-KBOI7
Davis Wireless VP2, WD 10.37s151,
--- RIPE Atlas Probe - 32849
Offline satcop
« Reply #399 on: March 27, 2017, 01:34:52 PM »
In the main file you have a typo for the default station.  Change the KXK58 to WXK58 and that should clear the issue.
