Poll
FARS?
Yes, Davis Daytime FARS is the answer
6 (18.2%)
Yes, Davis 24-hour FARS is the answer
12 (36.4%)
Yes, DIY FARS is the answer - here's a link
4 (12.1%)
No, don't bother
4 (12.1%)
I'll have the chicken
7 (21.2%)
Total Members Voted: 33
Author Topic: To FARS or Not to FARS that is the question  (Read 5946 times)
Re: To FARS or Not to FARS that is the question
« Reply #25 on: February 23, 2016, 06:35:50 PM »
Wonder what he means by redesign. Is the sensor larger or just not compatible directly without code change.
He said there's different "communication" issues with the new stuff. I am the last person on earth that should pick his brain about this so I'm somewhat paraphrasing it. That's where you "in the know folks" come into play.
FYI the specs for the SHT35 are 2% humidity across the entire spectrum and the temp at 0.2C, spectrum unknown, but certainly greater.
« Reply #26 on: February 23, 2016, 06:37:27 PM »
SHT15-SHT3X.... Digital Sbus vs I˛C, Voltage Out
Uuummmmm, ok. :???:
Offline ValentineWeather
« Reply #27 on: February 23, 2016, 06:54:04 PM »
Randy
« Reply #28 on: February 23, 2016, 06:59:34 PM »
This is what I want to interface with the VP2. https://store.vaisala.com/us/hmp110-humidity-and-temperature-probe/HMP110A15A1C3B0/dp
Frankly Randy, I think the SHT35 is a better overall performer, especially at the price point. :shock:
« Reply #29 on: February 23, 2016, 07:08:51 PM »
Also you would need a RM young type shield. Certified +/- 1.5% humidity isn't bad though.
Randy
« Reply #30 on: February 23, 2016, 07:19:51 PM »
Absolutely. The thing I prefer is that the 35's humidity is 2% from 0 to 100%. Since we spend a considerable amount of our time here below 10% humidity, I'd prefer the 35, especially for 20 bucks or so.
« Reply #31 on: February 26, 2016, 09:18:43 AM »
This is what I use for checking calibration. Remove dust screen, drilled a small hole bottom of shield (be careful doing this the plastic is brittle and can break) push the probe into the aspirated chamber. Works well, after removing probe I plug hole with plumbers putty.
http://www.coleparmer.com/Product/Digi_Sense_Calibrated_Extreme_Accuracy_Digital_Thermometer_0_00_25_00_37_00C/EW-90000-29
Noticed today my Nist-Tracable sticker expired in October.
Randy
« Reply #32 on: February 26, 2016, 04:12:42 PM »
If I keep seeing these kinds of post, I'm gonna hafta file for chapter 11.... #-o
Offline Old Tele man
  • Singing in the rain...
« Reply #33 on: February 26, 2016, 06:05:57 PM »
Do you make & record *comparison* tests periodically so you can detect any ±trends, or is it an annual event?
« Reply #34 on: February 26, 2016, 06:46:17 PM »
I don't keep any log I just check  several times a year. Last October made the -.6 correction. Checked again today and its still looking good.
Randy
