Jasiu, "You chose wisely"
Yes, today's update brings a fix to include-style-switcher.php (not touched since 2013) to avoid trying to set cookies when already done.
Thanks to lddaly, a simple fix to wxstatus.php corrects display issue present since 2012 (langtrans() v.s. langtransstr())
I also took the opportunity to make some adjustments to check-fetch-times.php (thanks to zmarfak) to:
1) clean up some HTML errors in the displays
2) add redaction of API key displays with both the show=settings and in the basic check-fetch-times.php run
3) add a Deprecated script check to alert you that an old file may now be removed.. currently only two are on that list:
(WU-forecast.php and get-nnvl-iod.php as the source data for both have dried up)
Thanks to all for the continuing feedback regarding the scripts!
