Author Topic: WEATHER34 TEMPLATE with meteobridge options  (Read 88349 times)
Offline txweather.org
    • Texas Weather
Re: WEATHER34 TEMPLATE with meteobridge options
« Reply #400 on: March 13, 2019, 09:28:03 PM »
All fixed. Beside the memory limit I also needed to upgrade to php7.2
All is well.
Thanks again!
Offline weather34
« Reply #401 on: March 14, 2019, 05:28:46 AM »
 [tup] good stuff have fun ..
Offline new2ark
    • AW1401-IP  Home • Weather • Station
« Reply #402 on: March 14, 2019, 09:50:43 AM »
DarkSky info is out of wack after upgrading Meteobridge and Weather34 website
i have been using Weather34 and Meteobridge for over a year and this new problem has me scratching my head...check out my website....https://pwsincabotar.com/
Offline weather34
« Reply #403 on: March 14, 2019, 10:37:51 AM »
i would say there is more than darksky issue going on here lots of 404 means missing files not on server or in directory .
Offline new2ark
« Reply #404 on: March 14, 2019, 10:41:19 AM »
Sorry....I wiped out my server files and are now uploading Weather34 to see if it would resolve the issue....should be finished in about 10 min....
Offline weather34
« Reply #405 on: March 14, 2019, 11:00:19 AM »
might also want to check file folder permissions ..
Offline new2ark
« Reply #406 on: March 14, 2019, 11:04:55 AM »
well before current conditions was working and forecast was giving me high temperatures from DS....now both arent working....hmmm
Offline weather34
« Reply #407 on: March 14, 2019, 11:06:59 AM »
pm password to setup screen you can change at anytime ..
Offline new2ark
« Reply #408 on: March 14, 2019, 11:59:43 AM »
3 new files did the trick....thanks for resolving this so quickly
    • Texas Weather
« Reply #409 on: March 18, 2019, 04:02:20 PM »
Quick question @weather34, I have setup the air quality monitor and the page does not seem to refresh it?
It still shows the default  the 192 Unhealthy AQI
Thanks for the help!
Offline seaman55
    • Seamanville Weather
« Reply #410 on: March 21, 2019, 11:09:43 PM »
Assuming you’ve set the right Purple ID, the next thing I’d try is making sure the permissions are set correctly for the folders and files in your web folder. Then make sure your cron job is running without error.
http://seamanville.com/pws
Davis Vantage Pro 2 Plus Daytime-FARS/Meteobridge Pro/ weather34 template on Raspi v3 B+/PurpleAir AQI sensor
Wireless ISS sitting ground/Wireless Wind, Solar, UV sitting roof
Monroe, Washington USA
WU:     KWAMONRO94
CWOP: FW4493
PWS:   FRYELANDS01
    • Texas Weather
« Reply #411 on: March 22, 2019, 12:28:36 PM »
The instructions did not talk about a cronjob... Can you point me to the right direction please?
Edit: Is it the services setup under meteobridge? If yes, Those are done... After the mysql change I am able to get updates. Not sure what was causing it... Maybe the stationcron.php was stopping due to the errors on the mysql.... Not sure... :)
« Last Edit: March 22, 2019, 12:37:47 PM by xcom »
Offline weather34
« Reply #412 on: March 24, 2019, 04:33:14 AM »
Good morning
files updated on the repo mainly reflect weather underground and moonphase module .
1.weather underground main page removed night time zero value for UV .
2.new very slim in fact so small Im amazed at its simplicity to achieve the output .requires moonpase.php,mooninfo.php and two css files to be updated.also has minor dutch correction in new moon layout languages/nl.lang.php.
this should be the version handed over next month the changes are minor but improves overall visual experience and clean output(theoretically)
via github you can either clone or just download the updated files look for the date in the listings .
https://github.com/weather34/Meteobridge-Weather34-Template
to get a smooth update process it is advantageous to learn and get to grips with github capabilities , ive used quite successfully in the last two months whilst a bit of learning curve is required but it really is the way to go in the future if you want to follow the updates easily.
like to thank these sites which I frequently monitor for anomalies I dont always see
Singapore Weather(UV readings unlikely to see here in Istanbul & really uncomfortable dewpoint readings that would permanently confine me to A room with 24/7 AC)
Bath(UK) Weather (UK mph with metric values)
Myrtle Beach WX (general non metric values)
Milehighweather (custom version)
Okawville WX( general non metric values)
Baxley, GA Weather Station (general non metric values)
Toulouse Meteo (custom version using multiple hardware types and multiple meteobridge hubs)
screenshots of Meteobridge MB-UB40-EDS version (what does EDS mean ? Earth Dies Screaming a song from my teenage youth years)
as always tested on current PHP public release now at 7.3.3
PHP version 5.x.x was declared End-Of-Life on January 1st 2019...
in short  PHP 7x is up to double as fast as PHP 5.6
side note I get a lot of emails about Weatherflow so here is the gist of my responses
1.weatherflow hardware is fully compatible with meteobridge hubs and you have near on full capability as seen with any other hardware connected
to a meteobridge hub.
2.having some new weatherflow hardware with improvements like the much needed solar powered addon (no more expensive lithium aa batteries which basically rapidly lose voltage/current in long cold spells ,ive gone through 24 in 14 months and rapid drop off rate is alarming) ,anti vibration mount addon(sceptical and await how it performs under 70kmh or more winds which get quite frequently in recent months), improved material coating to remove or reduce the loss of wind readings in rainfall periods (stormy and flash flood season is around the corner) .
3. there are no plans to have a dedicated weatherflow version whilst I have a version that works fine using the websocket protocol but big but its redundant unless the browser is open on your device,computer etc..so therefore purchasing a meteobridge hub will give you all the beneficial features currently available in the template .
4. weatherflow hardware is still a product thats evolving its newer haptic technology is a challenging method and I still remain on the sidelines in terms of rainfall measurements under steady to heavy rainfall .a tipping bucket or manual gauge still offers for me a more realistic measurement of rainfall .
as always have a great week ahead...
dont forget to follow Ken True's github page for Cumulus version...https://github.com/ktrue/CU-HWS
and Ian Millard Weewx version via github https://github.com/steepleian/WX-HWS
« Last Edit: March 24, 2019, 08:57:29 AM by weather34 »
    • Texas Weather
« Reply #413 on: March 24, 2019, 11:03:30 AM »
Thank you for this update!
Offline seaman55
« Reply #414 on: March 24, 2019, 01:42:49 PM »
Just got the Meteobridge Pro setup properly. Took it a while to arrive, mostly due to customs. Unfortunately Ambient Weather hasn't had them available for months, so had to order international.
The response time is a lot faster that the Moteino setup I was using to receive from my wireless ISS on the ground, and my wireless Wind/UV/Solar sensor setup on the roof. I am still using the Moteino to send to my Davis console which is feeding the AW site since they won't license a MB Pro that isn't purchased through them. I made a custom 915MHz antenna for the Meteobridge pro to improve signal.
The little Raspberry Pi is running MySQL and Apache just fine for hosting the weather34 template.
I just need another UPS for the POE switch that is feeding power to the Raspberry Pi and Meteobridge Pro.
Everything looks to be working well now though.
WU:     KWAMONRO94
CWOP: FW4493
PWS:   FRYELANDS01
Offline weather34
« Reply #415 on: March 25, 2019, 03:20:06 AM »
good morning
i was going to reply yesterday got sidetracked , playing with antennas can be rewarding i really miss my amateur radio days especially building antennas at VHF/UHF i was obsessed with weak signal reception and the day i first heard W5UN signal reflected off the moon back in the UK I was a happy man as I was using a home made antenna array elevated..
Im no expert on Raspberry PI in fact complete novice to the point no idea where to start lets break it and learn ...
Not sure what size UPS you use but Ive always had a UPS running living in a district that radomly weekly the electric shuts down and nothing to do with weather but I use it like this my UPS i recently replaced as my wife constantly plugging her laptop into it so I gave it to her and bought another roughly $70 but Im sure a 600va or 850va at low cost would be sufficient , i get around 46 hours with no electric with all my hardware connected .so I do it like this
Aside the meteobridge products certainly are versatile and rich in data the more you use it the more you discover its capabilities the template now uses 171 different values(strings) generated by meteobridge software and there are many more ..so have fun...brian
Offline alexeysailman
    • MORSKAYA10 WEATHER STATION
« Reply #416 on: March 28, 2019, 02:44:35 AM »
Hello again, Brian! Used the last update of your template. I noticed an interesting feature (seen in the picture): judging by the timeline displays not only the last day, but previous.
Offline weather34
« Reply #417 on: March 28, 2019, 03:03:18 AM »
at a guess i would say your end of day did not run ...truncate
under services tab in meteobridge what time is empty.php set to run other than that cant think of anything why you would have multiple days in the day charts , is it the same for wind etc ..? please always provide a url then i can see it realtime ..
« Reply #418 on: March 28, 2019, 11:19:05 AM »
Thank you for your time. All done as Your instructions: https://www.weather34.com/homeweatherstation/guides/setupmeteobridge.html
By the way, the same applies to wind and temperature.
https://xn--10-6kcwaznenhomt1p.xn--p1ai/
I did not change the settings of meteobridge. Version of your template (before the latest revision) to work correctly. I did not replace the files selectively, so I completely deleted everything on the server, and then copied the latest version of the template again, configuring it again.
« Last Edit: March 28, 2019, 02:08:01 PM by alexeysailman »
Offline weather34
« Reply #419 on: March 29, 2019, 01:00:32 AM »
looks ok now , as I said i think the end of day was not running its the only way the data from previous days are still present .. anyway have fun and dont forget to change your purple air heading to moonphase :-)
Offline weather34
« Reply #420 on: March 30, 2019, 04:44:48 AM »
a look back did it change that much ??
https://weather34.com/homeweatherstation/weather34timeline/weather34timeline.html
and who knows the future
have a great weekend..brian
    • Texas Weather
« Reply #421 on: March 30, 2019, 05:46:37 AM »
Awesome time line!
Offline prestwickwx
« Reply #422 on: March 30, 2019, 09:20:11 AM »
Brian,
Very interesting timeline!
Chuck
« Reply #423 on: March 30, 2019, 10:11:33 AM »
Do you want a copy of any of the old zips?  I've got a few ;)
Offline weather34
« Reply #424 on: March 30, 2019, 11:14:02 AM »
ha ha keep em mate might be worth something one day -:) i have them all and  i have stuff i started on in 2010 then got sidetracked on other stuff didnt realize i was dabbling in weather screens so long ago....still none the wiser and wouldnt do it all again probably settle for something less complex like collecting football cards..have a great weekend..
