Have a question....I have the Ambient Weather WS-2000 Osprey uploading station data to AMBIENTWEATHER.NET. I have a Davis Vantage Pro2Plus WLIP uploading to WEATHERLINK.COM. I do have a AMBIENT WEATHER WEATHERBRIDGE. Would it be possible to connect the DAVIS VP2PLUS W/ WLIP to the WEATHERBRIDGE and also connect the same station to a WEATHERLINK LIVE?
Yes, you can use your WLIP to connect to the Meteobridge and continue to upload to Weatherlink.com What does any of this have anything to do with your WS-2000?
I also have a WEATHERFLOW Tempest uploading station data to WEATHERFLOW. I have read where METEOBRIDGE does support this station. Does the WEATHERBRIDGE support the Tempest station?
The WeatherBridge is a Meteobridge. It is the same exact thing. The only difference is that what Ambient calls a WeatherBridge is their version with added Ambientweather.net upload license. I just refer to a WeatherBridge by its proper name ...a Meteobridge...because that is what it is. Just because Ambient wants to call it something else does not change what it really is. Boot up a WeatherBridge and it doesn't say WeatherBridge anywhere...it says Meteobridge.
The Meteobridge does support Weatherflow Air and Sky. I don't know if that means if it also support the Tempest. But if you are using the Meteobridge for your Davis station then you can't also use it for your Weatherflow. The Meteobridge only supports one station type at a time.
Just trying to utilize the ease of webcam image loading that WEATHERBRIDGE offers. Any suggestions? Thank You!
Whatever station you decide to connect your Meteobridge to should not impact what you do with your camera. They are two totally different things. The webcam handling on the Meteobridge is a completely separate function. Other than of course the overlay data will be of whichever station you decided to run the Meteobridge with. But if you wanted you could do without the overlay and just have a webcam image. Then you can provide that image to whichever online reporting each station does. The Meteobridge produces at the same time the image with and without the text overlay. You get to pick the given URL for the image with or without text.
