Author Topic: Internet Explorer 8  (Read 8740 times)
Offline optrex
Internet Explorer 8
« on: February 24, 2010, 11:47:10 PM »
I know support is not through these forums, but I would like feedback from users on the following.
My weatherflash install works fine in firefox, ie6 and 7 but when it comes to ie8 its just "accessing data"
Any pointers? presumable a code change but I am sure others will have come across this before
php5 install
Offline optrex
Re: Internet Explorer 8
« Reply #1 on: February 24, 2010, 11:56:47 PM »
self diagnosed, it was the carriage return in the key file, but I am not sure why it only affected ie8
I wish support was offered by the forum I am sure the lack of published support posts must hinder the progress of the package in terms of its use in weather sites.
Offline Weather Display
« Reply #2 on: February 25, 2010, 12:51:17 AM »
but support by Meterologica is provided on this part of the forum
Brian
info@weather-display.com
Offline Dabbling
    • Mason Neck, VA. Weather
« Reply #3 on: March 04, 2010, 11:00:11 AM »
Just purchased and experienced same issue -fine with Fire Fox but with IE 8 it seemed to get in endless loop while loading virtual instruments. The carriage return removal did the trick - thanks!
Davis 6152/WeatherLink Serial (Serial to USB)
VWS 14.0/VWSaprs 1.9.8.0
CWOP - DW3803
WU - KVALORTO7
Offline DaculaWeather
    • North Georgia Weather
« Reply #4 on: March 04, 2010, 11:44:54 AM »
The most difficult thing about all of this is making everything work in every browser and unfortunately, IE anything is a pain in the ass.
If you look at the navigation menus on my site, I had to make it where sub menus overlap using Firefox, Chrome, and IE8 (I don't even bother trying to make IE 6 work) but in IE 7, it looks perfect.
You would think that someone like Microcrap could design a browser that renders things like they're suppose to be.
They are the web developers worst nightmare.
Offline willper
    • Front Range Weather
« Reply #5 on: March 05, 2010, 11:22:13 AM »
I am having a similar issue in that a graphic will not show in Firefox and it will in IE 8. Have any of you experienced this?
« Reply #6 on: March 05, 2010, 11:46:26 AM »
If you can show me the code, I'll try to help you.
« Reply #7 on: March 05, 2010, 12:33:47 PM »
I've actually found Internet Exploder 8 to be pretty decent.
Offline willper
« Reply #8 on: March 05, 2010, 12:44:29 PM »
Drac, I am not sure what code you want to see. Is it the index.htm?
If you view my WeatherFlash site in IE and then in Firefox you will see what I mean.
« Reply #9 on: March 05, 2010, 12:51:26 PM »
A quick fix is to add a meta tag on any page which you want to render as version 7 or below.
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
« Reply #10 on: March 05, 2010, 01:06:19 PM »
I have more trouble with 7 than I do 8. We have 7 at work and I have 8 at home.
Offline willper
« Reply #11 on: March 05, 2010, 03:14:57 PM »
I guess being able to go to my site would help.
http://www.ophirgardensweather.com/index.htm
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #12 on: March 05, 2010, 05:34:16 PM »
Willper,
There is some limitation in Firefox that won't allow it to render the images.  I spoke with Tim about this some time ago.
Jay
Davis Vantage Pro2 Plus
VVP
Weather Display
« Reply #13 on: March 05, 2010, 05:34:48 PM »
Are you using compatibility view? I'm not using compatibility view and it works on my IE8 and I see the cam image. In Google Chrome, I don't see the cam image at all. Also, there is a box  to the left of Evapotranspiration that doesn't show in either browser.
Offline Meteorologica
« Reply #14 on: March 06, 2010, 03:00:23 AM »
Definitive answer: WeatherFlash's graphic image object only works in Internet Explorer. They do not display in any other browser type.
Offline willper
« Reply #15 on: March 06, 2010, 12:03:46 PM »
Could you please tell us why it only works in IE?
« Reply #16 on: March 06, 2010, 12:38:30 PM »
Because the Flash implementation on IE is different from other browsers. Ask Macromedia why not us!
« Reply #17 on: June 24, 2010, 02:49:57 PM »
Everything is different on Microcrap products!  :grin: Also, Flash is now an Adobe product and no long Macromedia.
The hardest part about creating my site (from scratch BTW) was making everything look the same in all the browsers.
