Wait a minute. I'm confused. Lets clarify. You took the rain transmitter and hooked it up to the temp sensor and you still are not getting a reading from the temp sensor, is this correct?
What happens if you take the transmitter that was on the temp sensor and connect it to the rain sensor, do you get a reading?
If so. Then is't the sensor it's self that bad and not the transmitter.
