So as promised, finally after about of month of intensive work over nights I managed to put together first preview of the template I am working on. So far it is still a long way to go and I am only posting some screenshots and videos. There are two videos showing the actual template and one video showing how the settings will look like. It is just for you to get an idea of what I am doing. I also made a few higher-resolution screenshots of randomly generated design combinations, which I am attaching as a ZIP file.
if you are interested you can watch them and in hopefully near future I will have a first “beta release”, which will not be just a video, but the real thing and to those that showed interest in testing I will send a PM or email.
Just a couple of important things before watching:
1. Most importantly… please excuse the video quality. The real thing is of course nice and sharp, but when I tried recording in HD, my 1GB RAM laptop completely froze… even the medium quality led to BSOD, so I had to record on the lowest quality. Still I hope in fullscreen most of the fonts are legible. Also the lagging and slow loading is due to the fact I was screen capturing while looking at it and it normally runs much faster.
2. The template is currently hooked to my own PWS and database. I measure data since 1st January 2012, which is why in all cases you will see that data and menus etc. go back to 2012, but this of course will adjust depending on what your data will look like.
3. Video number 3 is a preview of how the configuration will look like. One of the options is also solar sensor. My WH1080 doesn’t have one, which is why all the graphs and tables in the preview for solar radiation are blank. Normally if you don’t have one, you would set this parameter in the config file to false and all tabs, tables, icons etc. of the solar radiation will not be visible on your site. But for demonstration purposes I left it on true and therefore had zeros everywhere.
4. The template uses purely javascript, CSS, PHP etc., but no potentially unsupported plugins such as Flash, Silverlight and also no cookies. Compatibility tested in Chrome, Firefox, newest IE, Opera, Maxthon, Nitro and also on mobile devices (Android). I don’t have access to a Mac, but tried it once in Safari on iPad and iMac and worked ok.
5. Everything you see is calculated in real-time, which means even the most recent data is taken into account in all the graphs, stats etc. In order to achieve fast loading times I tried to implement AJAX and dynamic loading as much as possible and there are also mechanisms that for example pre-load other tabs in the background while already show you something (you will see what I mean if you watch it).
Keep in mind this is just the very first version and still long way to go. My plan is to have more sections. The videos only show the “weather station” section, then you will have options of many different “plug-ins” or pages that can be added. It is fully compatible with basically anything and I will then be releasing new scripts, which I will call “plugins” and just by placing them into the plug-in folder of the template, they will show up in the main menu. So for example there will definitely be my already released scripts – the forecasts, banners, climates, observations, I will also do many more based on my current personal webpage and new ones. So for example the top banner can be the one I already made, interactive one etc.
An essential part of the whole template will also be scripts to help you with the initial set-up – i.e. scripts that will automatically create databases and tables and I hope I will be able to also make scripts that will automatically import historical data from outputs from software such as weather display, cumulus or even fetch them from WU. I have already done some testing and it should be possible. I recommend using 5min intervals in the db, which meant 1 yr worth of data took about 30 s to import and remember you only do this once at the beginning, so if you have say 10 yrs of data, it would take you maybe 20 minutes to set up. If you measure at shorter intervals (1 min) it is of course possible to use as well, but 5 mins is ideal and there are mechanisms integrated that make sure you don’t miss any extremes etc. even with 5min interval, which I would explain later. Importing scripts will do everything automatically and I plan to also make checking mechanisms, that will for example check the data is valid, send alerts via emails etc.
Yes I do have lot of plans
So in conclusion, this is really just the first preview of the first part, but I wanted to have some feedback already so that if there is something you think I should do differently or if you think this whole thing is not really worth finishing, let me know and I will take all comments into account.
Videos:
PART 1 -
https://www.youtube.com/watch?v=iryjHSe3NbkPART 2 -
https://www.youtube.com/watch?v=WEOmTe2DsQcSETTINGS -
https://www.youtube.com/watch?v=ahs6Gq305fwScreenshots:
http://www.megafileupload.com/1OkM/imgs.zip
