Hi!
It's Thursday evening again (here). So I've archived the results of the last poll back into
post #2 and started
a new poll.
This time it might be about a topic that is not so relevant for most users. But that's exactly what a survey should be able to show.
My wife complains from time to time that the console (there are several in the study) is always switched on. No matter whether someone wants to look at it or not. Whether I am present or not. Even on holiday, when no one is really interested in the display.
The display switches itself on - time-controlled - in the morning and then off automatically in the evening.
And it consumes electricity.
According to my own measurements, the HP2551C (old revision - without WebUI) needs approx. 500mA in operation with display and approx. 200mA when the display is switched off.
So that's a difference of about 300mA. At 5V, this adds up to about 8 kWh per year (if I have calculated correctly).
Even with the significant increase in energy prices, the monetary value that can be saved is small.
But it's the sum that makes the difference - several devices with low consumption add up to a noticeable consumption.
Every little bit helps.
And it's not just the energy savings. The TFT is certainly also designed for a certain durability, which depends on the running time.
You don't really have to use up this running time uselessly, do you?
And the slightly guilty conscience about the waste of resources ...
Of course, I could always leave the display switched off and only switch it on when needed. But that's not a nice option either: lack of comfort. Sometimes you want to look up quickly - and then you have to go to the console and maybe press a button?
No, the device remains on time-controlled.
And consumes electricity.
One solution could be to integrate a motion detector (or presence detector) into the console that automatically switches on the TFT when motion or presence is detected and switches it off again after an adjustable period without motion (with re-trigger). That would be a unique selling point - no other weather station does that yet!
My idea is that you can also switch off the motion detection - i.e. permanent operation or permanent or time-controlled switching on/off remains possible.
But it would also be helpful to be able to switch the display on and off via WIFI. Just as you can now configure the weather services via app and API, you should also be able to switch the TFT on and off via app/API. This would make it even easier to integrate the console into a smarthome and activate it via external motion sensors, for example.
Hence the question:
Is an integrated motion sensor or an API solution for switching the TFT on and off desirable?
What do you think?
Oliver
