Author Topic: WU Dashboard and History  (Read 2088 times)
Offline Platokidd
  • top side land of Lincoln
« on: September 20, 2022, 04:54:36 AM »
The WU dashboard does not show my pws data. However, it does show my weather history.
Tried changing the console that I'm using to send data to resolve issue. Also emailed wu without reply.
Any idea how to resolve this issue?
https://www.wunderground.com/dashboard/pws/KILPLATO3/table/2022-09-20/2022-09-20/daily
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Online wvdkuil
  • Wim van der kuil
Re: WU Dashboard and History
« Reply #1 on: September 20, 2022, 05:11:52 AM »
I seem to have a similar problem, three of 5 stations in two WU-accounts are "off-line" although there data is up-to-date and very similar.
You have three stations at WU: KILPLATO3 KILROCK100 KILCRYST84
Are they in one  WU-account? Or do you have two three separate accounts?
Regards,
Offline weatherdoc
    • Willowsford Farm Weather
« Reply #2 on: September 20, 2022, 07:13:41 AM »
My station is showing offline as well, but the graphs are current: https://www.wunderground.com/dashboard/pws/KVAALDIE28. Weather Display feeds WU.
Online wvdkuil
  • Wim van der kuil
« Reply #3 on: September 20, 2022, 07:26:32 AM »
Indeed, it can not be an upload-problem as the "off-line" stations use multiple different uploading-programs (WD, MB, Ecowitt, WF) which are also used by stations which remain on-line.
Also both "off-line" and "on-line' stations appear with similar values on https://www.wunderground.com/wundermap
Only when you click on the stations-value one can see that a station is "offline" or "online" on the stations-page.
Strange that WU finds the "offline"-stations data good enough to use on the wundermap map.
So what is "wrong" with those stations to be labelled "offline".
Problem is WU does not to sent mails when a station goes "off-line" as other network  to warn you f.i. that a station goes off-line because "temperature is out of range with adjacent stations."
And the data is still arriving at WU, it appears on the table and graphs.
When I check the data, I do not see any strange values when comparing "off-line" and "on-line" stations.
« Last Edit: September 20, 2022, 07:40:21 AM by wvdkuil »
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #4 on: September 20, 2022, 07:41:18 AM »
This must be all related?
https://www.wxforum.net/index.php?topic=44397.0
Some mess on the go.
Offline alanb
« Reply #5 on: September 20, 2022, 09:09:28 AM »
Hopefully this is an indication that WU is working on resolving the problems that have been going on for almost a week now. I would guess they have a time-consuming task of recovering/reconstructing the WU database.
Offline Calochortus
« Reply #6 on: September 21, 2022, 09:13:32 PM »
Seems to be fixed now.  Bad weekend for the DBAs.
Offline WheatonRon
    • WUnderground
« Reply #7 on: September 21, 2022, 09:38:34 PM »
Below is a post regarding WU I recently made in a different thread (https://www.wxforum.net/index.php?topic=44397.msg451699#msg45169) but related in the WXForum.
WU is really weird and funky these days. If you view your pws dashboard on WU-weather history (bottom of the WU dashboard page-see example in the link below to one of my pws) from say 1990, there is some data, even though in my case that is years, actually, decades before I started uploading data to WU! That data belongs to which pws—not mine. Talk about goofy! Does anybody at IBM look at WU or care?
https://www.wunderground.com/dashboard/pws/KILWHEAT17
« Last Edit: September 21, 2022, 10:52:33 PM by WheatonRon »
Offline jerryg
  • weather is never boring
    • victoria texas weather
« Reply #8 on: September 21, 2022, 10:43:13 PM »
Well well well, i got mine up and running again, i had been using the password that i have had for years and working fine. I decided just for fun to change out my password for the api key and bingo  it is now back on line and working right. I guess they killed the original passwords or something.
Offline WheatonRon
    • WUnderground
« Reply #9 on: September 21, 2022, 10:45:47 PM »
Give it at most, a few days. It will quit working.
« Last Edit: September 21, 2022, 10:51:28 PM by WheatonRon »
Offline lwman
« Reply #10 on: September 22, 2022, 06:51:48 AM »
My PWS has been offline for about 18 hours. The data that it is sending to my acurite is up to date. Hopefully they'll get it going today.
Offline jerryg
« Reply #11 on: September 22, 2022, 08:33:28 AM »
My stuff is still running this am but i now don't have any graphs just a bunch of numbers on the left side going down to the bottom of the page. It looks like graph info but numbers instead of lines. This is a first time for this problem.
Offline joegr
« Reply #12 on: September 22, 2022, 09:58:31 AM »
It looks like the history graphs work in weekly and monthly mode, but not daily mode.
Offline boss281
« Reply #13 on: September 22, 2022, 12:56:22 PM »
Mine crapped out several days back, and would intermittently come back up with or without the summary data. Now, like others have observed, the daily graph view is dead. If I go to weekly mode I see it going offline around 10:30am Eastern time on the 21st. Just have to wait and see if they can fix it...
Weather Underground PWS KMDNEWWI3
« Reply #14 on: September 22, 2022, 04:26:27 PM »
WU seems to have made a change and no longer accepts your WU password for upload of conditions.  You have to use the device key (shown in the Devices section in WU) instead.  I made the change, and my station resumed reporting today .. it had died at 9am PT yesterday.
Offline weatherdoc
« Reply #15 on: September 22, 2022, 06:50:25 PM »
I've used the device key for a long time and I've had the same issues as everyone else the past few days. Now it looks like the only data permanently missing is from 6:20 PM ET yesterday through 9:25 AM ET today but everything has been working since then.
One thing that may only be a coincidence is that my irrigation system controller, Rachio, sent me an email today indicating that as of Oct 1 they will no longer be using PWS Weather (https://www.pwsweather.com/) as their weather inputs for determining what days to water (or not) but they are switching to WU. Furthermore, they stated "To get the most out of a single station, we recommend using a Tempest Weather System which fully integrates with the Rachio App and does not require a third-party service." But, my Davis sending data to WU will still be used by Rachio. Most of my neighborhood with houses that have irrigation systems rely on my weather station feed to Rachio and control their watering days. So, maybe WU was making changes to support working with Rachio's database? Probably not, but you never know!
As usual, Ken, thanks for tracking this down and posting it. Fingers crossed that the WU changes and using the device key has straightened things out.
Offline Gulfstream4
« Reply #16 on: September 22, 2022, 08:06:21 PM »
This ^^^ is exactly what I did to get my station back on line. Thanks to all for the suggestions!!
Offline Platokidd
« Reply #17 on: September 22, 2022, 09:34:03 PM »
Regards,
All 3 pws on 1 account. Pws in question is now working ;)
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
