Author Topic: CAP alerts flaky for anyone else  (Read 464 times)
Offline Jasiu
    • LexMAWeather
« on: August 21, 2019, 09:20:41 AM »
Is anyone else seeing flakiness with accessing CAP alerts from alerts.weather.gov? I've seen cases in the last couple of days where active alerts are either not returned or marked as expired when, in fact, they are still active. And the situation comes and goes. After one fetch, the alert will be there. Next fetch, gone. Next fetch, back again.
Maybe it's just my local office (BOX). Ironic thing is that the beta JSON API seems to be working better at this time.
Example right now if you happen to read this shortly after I wrote it...
If you go to:
  https://forecast.weather.gov/MapClick.php?lat=42.441700000000026&lon=-71.23156999999998#.XV1D7FApDOQ
you should see that there is a special weather statement that covers the entirety of the BOX area. However, the following URLs sometimes have the alerts, sometimes not (and can be inconsistent between themselves):
https://alerts.weather.gov/cap/ma.php?x=1
https://alerts.weather.gov/cap/wwaatmget.php?x=MAZ014&y=1
https://alerts.weather.gov/cap/wwaatmget.php?x=MAZ005&y=1
https://alerts.weather.gov/cap/wwaatmget.php?x=MAZ026&y=1
The first of these URLs had the alert when I first checked just now. And now it is gone....
https://lexmaweather.info
Offline Maumelle Weather
    • Maumelle Weather
Re: CAP alerts flaky for anyone else
« Reply #1 on: August 21, 2019, 09:31:00 AM »
My NWS-Alerts script did that exact thing several times yesterday. We had both a Heat Advisory and a Excessive Heat Warning at the time, and at least 2 times, it had no advisory/warning at all. It showed clear.
GR2AE, GR3, Cumulus
Offline Jasiu
    • LexMAWeather
« Reply #2 on: August 21, 2019, 09:53:59 AM »
I sent an email to the NWS folks... will report back.
Offline SoMDWx
    • Southern Maryland Weather
« Reply #3 on: August 21, 2019, 11:26:53 AM »
Yes, saw the same thing yesterday with severe weather all around me here in So. MD. Had 3 counties with SEVERE THUNDERSTORM  WARNINGS and then poof! all clear  then...back to warnings....
Offline rrrick8
    • Vermilion weather
« Reply #4 on: August 22, 2019, 09:08:17 AM »
Yep, same problems. Alert icons and details kept going in and out.
Severe Weather Manager-Vermilion County EMA
CWOP-CW9931 KILDANVI5
