Author Topic: warning: new firmware update v1.6.2 for GW1000 seems to be broken *SOLVED*  (Read 2451 times)
Online olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
UPDATE: This issue is now resolved. New Firmware 1.6.3 upgrades nicely and does not delete your configuration/data
Hi!
There's a new firmware out for GW1000 (and same for WH2650):
New Firmware GW1000V1.6.2:
1. Change the IP of WU.
2. Correct the signal interval of WH34.
So the same changelog as for v1.6.1 ...
Attention!
This firmware update deletes all configured weather services except Ecowitt (including custom server!)!
So you have to reconfigure manually all services afterwards.
Additionally all calibrations and rain rates are gone now.
In addition, the IDs of my soil moisture sensors (at least) have also been rearranged - the names given no longer match.
Time zone will be set to UTC
I am not sure if this behavior is desired by FOSHK/Ecowitt.
update:
In the meantime, FOSHK has improved the update description:
1. Modify the WH40 rainfall
another update:
Ecowitt updated again the description:
1. Modify the WH40 rainfall algorithm to prevent inaccurate rainfall measurement during rainstorm.
2. Support WH45 Co2 sensor
Oliver
Offline MacGarage
  • SW Ohio
Re: warning: new firmware update v1.6.2 for GW1000 seems to be broken
« Reply #1 on: August 29, 2020, 08:54:36 AM »
It seems to have wiped out my entire rain history for the year, month, and day.
I can also confirm that I lost my weather reporting services as well.
« Last Edit: August 29, 2020, 08:56:16 AM by MacGarage »
Ecowitt WH2320E
AcuRite Atlas
« Reply #2 on: August 29, 2020, 10:15:44 AM »
Strange that they would release a firmware update on the weekend. I think this update will end up being either pulled or superceded quickly. I'm holding off and staying put with 1.6.1.
« Reply #3 on: August 29, 2020, 10:27:42 AM »
I just sent Ecowitt the following email.
If like to inform you that the recent release of firmware 1.6.2 is causing concern among users of the GW1000. This 1.6.2 version is erasing all settings, all upload services and all calibrations, and rain data totals from the GW1000. This is rather unfortunate.
If this is a bug then I recommend stopping the distribution of 1.6.2. If this is necessary and cannot be fixed then the notification pop-up in WS View for update should inform the user to first write down all their rain data totals and their calibrations, and to also be mindful that they will need to enter upload services credentials. There needs to be a warning if this cannot be avoided.
Offline Gyvate
Warning on GW1000 Firmware update to 1.6.2
« Reply #4 on: August 29, 2020, 01:00:21 PM »
Attention. The update will set all calibration to default values and the rain totals to zero.
Better keep note of them and re-enter directly after the update.
Online olicat
    • FOSHKplugin
Re: Warning on GW1000 Firmware update to 1.6.2
« Reply #5 on: August 29, 2020, 01:04:14 PM »
yes, you're right.
And also all configured weather services get lost ...
Already mentioned here.
Oliver
Offline Gyvate
« Reply #6 on: August 29, 2020, 01:08:16 PM »
This is (+/-) the same as the posting from olicat "warning: new firmware update v1.6.2 for GW1000 seems to be broken", which I saw only now.
Can only confirm his observation.
- calibration reset to default (including relative pressure !!)
- rain totals to zero
- all weather services except ecowitt.net erased
the newly entered weather services will only once you reset the device (disconnect from electricity and reconnect)
I waited for 45 minutes until I did so, then finally the data arrived again (here Weathercloud.net)
« Last Edit: August 29, 2020, 01:24:56 PM by Gyvate »
Offline Gyvate
« Reply #7 on: August 29, 2020, 01:26:49 PM »
the newly entered weather services will only work once you reset the device (disconnect from electricity and reconnect)
I waited for 45 minutes until I did so as nothing changed at the Weather website; then - after the reset/cold boot - finally the data arrived again (here Weathercloud.net)
Also need to manually change some databases as my Meteobridge handles the newly entered rain totals of today as a new rain occurrence ...
Already changed in the MB Pro DB
Maybe should have just left the value for raintotals today on zero   #-o
« Last Edit: August 29, 2020, 01:53:22 PM by Gyvate »
« Reply #8 on: August 29, 2020, 02:31:35 PM »
Posts above have been merged from two threads. Please check before posting a new thread.
George
Offline Autofill
« Reply #9 on: August 29, 2020, 03:14:55 PM »
Thanks for the warning. Will watch this thread before I update.
I know ecowitt was working yesterday night (their Saturday) because I got email responses and they were on social media.
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Online olicat
    • FOSHKplugin
« Reply #10 on: August 29, 2020, 04:40:59 PM »
In addition, the IDs of the soil moisture sensors have also been rearranged - the names given no longer match.
Now I have to check each and every one of them whether the name assigned in WS View (and PWT and ecowitt.net and PWSDashboard and ...) still matches the ID/Ecowitt name.
I'll probably just plug the sensors into their actual location now.
I've updated the first post with this issue.
Grrr, the update gave me a lot of useless work ...
I hope this doesn't become the rule now!
Lucy?!
Oliver
Offline Autofill
« Reply #11 on: August 29, 2020, 04:48:15 PM »
This sounds like there was a factory reset once the update was applied.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Online olicat
    • FOSHKplugin
« Reply #12 on: August 29, 2020, 04:59:49 PM »
Hi!
Yes. But wouldn't the WIFI also be lost with a factory reset? I didn't have to do any initial setup - the SSID and WIFI-key were still known.
I haven't (intentionally) done a factory reset, so I don't know.
Oliver
Offline ramblinche81
« Reply #13 on: August 30, 2020, 09:46:57 AM »
My firmware update froze, never initiated. WSView lost my gw1000 device. Tried to treat like new device and install and system will not make a device to device wifi connection.
July 2020
Ecowitt GW1000B gateway @ ecowitt.net
Ecowitt WN51 soil moisture x8 (potted plants and landscape beds)
Ecowitt WH57 lightning
Ecowitt WH31 temp x2
Ecowitt WH40 rain gauge
Ecowitt WS68 wind sun sensor
Dragon Touch tablet display with PWT app
Offline Jibster
« Reply #14 on: August 30, 2020, 11:36:48 AM »
Kind of related to this (maybe). I did a reset last week because I was having wifi issues. After which, I thought I lost everything on the GW1000. It did not show up in WS View. Then I added the GW1000 device back into WS View and all data was gone: calibrations, units, rainfall history, and services. Without making any changes, I checked WU, weather cloud, and ecowitt.net, and all were still reporting...huh? Then I went back to WS View and all was normal. I'm just saying this because I don't know where the data went or came from, but it did magically reappear after about 15 minutes so if you do think you lost everything, you might want to wait a few minutes before messing with it because it might come back.
FYI- I am reluctant to update the firmware now (thanks for the warning), so I am holding off for now.
ECOWITT GW1000 | WH32 | WS68 | WH40 | WH57
KNCRALEI888
Offline Gyvate
« Reply #15 on: August 30, 2020, 01:06:47 PM »
Lucy?!
Oliver
Same/similar observation here - for all sensors (which you of course only notice if you have more than one of the same type).
My 5 Soil Moisture sensors were regrouped (no obvious order, neither ascendending nor decending, probably in the same sequence in which they were picked up again by the GW1000).
I regrouped them physically into the old order/sequence.
Same happened to my two PM2.5 sensors - they now appear in reverse order - and I had to exchange them (physically, as I didn't want to go through the hazzle in the WS View app).
After having done all this (reprogrammed weather services, entered calibration (pressure) and rain totals and re-arranged the sensors SM and PM2.5) all works normal again.
Looks like 1.6.2 works ok - only the update process is sort of very radical.
« Last Edit: August 30, 2020, 01:11:05 PM by Gyvate »
Offline 2thepoint
    • NJ WeatherCat
« Reply #16 on: August 30, 2020, 09:16:04 PM »
Is there a way to back version to v 1.6.1 ????
GW1000
HP2551
GW2000
WS90
WH41B
Meteobridge/RPi4
Offline Brian78tx
« Reply #17 on: August 30, 2020, 10:36:13 PM »
Also, after this update, I noticed my time zone was way off yesterday evening.  During a rain shower at 6pm here in Texas, I noticed my rain for the day on the Ecowitt.net graph dropping down to almost zero and then increasing again after 6pm.  Turns out, after the update, my time zone was set for Dublin, Ireland!  6 hours ahead!  Luckily I got that back on track before midnight.  BUT. This evening I noticed my 2 soil moisture sensors were flip flopped.  So in trying to figure that out, I renamed them correctly back in the WS View app.  But they weren't changing on Ecowitt.net.  I didn't know how to change the name there.  So I think I just royally screwed up.  I think I made a fatal error.  I went to Ecowitt.net and hit the X on my device (weather station) and then added it back, and I think in the process I have now wiped out my WHOLE data history since May when I first got this GW1000 system!  I thought the server would have recognized the same MAC address and restored the data.  Oh well.  Not happy right now, all because of this screwy update.  I guess all I really care about are the rain totals, which I was able to piece back together last night, which I do still have before this screw up.
Brian
« Last Edit: August 30, 2020, 10:48:22 PM by Brian78tx »
May 2020
Ecowitt GW1000 gateway
Ecowitt WS80 ultrasonic anemometer array
Ecowitt WH57 lightning detector
Ecowitt WH31 temp/humidity x3
Ecowitt WH51 soil moisture x2
Offline Autofill
« Reply #18 on: August 30, 2020, 10:40:50 PM »
Looks like somebody at Ecowitt got the message. I haven't applied the update and kept pressing cancel whenever I wanted to see my GW1000 data, however, now it's not even asking me to update anymore to 1.6.2
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Autofill
« Reply #19 on: August 30, 2020, 11:53:23 PM »
A fix has been published, v1.6.3 and I just updated it from 1.6.1 and all is well. I didn't loose any data.
Did you get all your lost data back for those updating from v1.6.2?
« Last Edit: August 31, 2020, 12:30:01 AM by Autofill »
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Gyvate
« Reply #20 on: August 31, 2020, 05:12:01 AM »
With 1.6.3 all remained the same for me (after the update to 1.6.2 I had re-entered pressure calibration, rain totals etc. and reset the SoilMoisture and PM2.5 sensors physically, so the new channel/sensor ID combination would represent the old location again).
So no changes to the manually updated settings - however the lightning data from yesterday received after the upgrade to 1.6.2 got lost in the WS View app (of course not in my Meteobridge though).  So that's survivable.
So I'm not a good example for whether the 1.6.1 data remain/come back for 1.6.2 upgraders who didn't change anything after their upgrade. Lightning info disappearing is a bit naughty, but with the next lightning occurrence they will be newly set anyway.
Offline Jibster
« Reply #21 on: August 31, 2020, 10:11:10 AM »
I did not update to 1.6.2 after seeing the warning here. A few minutes ago, I went ahead and updated my GW1000 to 1.6.3, and it looks like it kept all history and settings. Hooray!
KNCRALEI888
Offline lemuba
    • Fitzbek-Wetter.de
My update from 1.6.1 to 1.6.3 went fine! Thanks for the warning in time!
Offline Shvedi
Re: warning: new firmware update v1.6.2 for GW1000 seems to be broken *SOLVED*
« Reply #23 on: September 01, 2020, 08:27:37 AM »
Same here. Thank you Olicat  =D>
Offline _John C
« Reply #24 on: September 05, 2020, 05:17:26 PM »
Anyone with leak sensors and 1.6.3 ? My leak sensors will not connect with the GW1000 anymore. Still working fine on the HP2551C. Only thing that has changed recently is that I updated from 1.6.1 to 1.6.3. I tried to re-register ch1 a few hours ago and it still has not registered.
« Last Edit: September 05, 2020, 05:25:15 PM by _John C »
Ecowitt GW1000CA x2,   HP2551CA,   WH65 Outdoor 7in1 2 arm array,  WH32B Indoor Temp/Hum/Baro, WH45 Co2/PM2.5/PM10,  WH41 PM2.5,   WH57 Lightning Detector,   WH31 Temp/Hum x8,  WN34L Liquid Temp x2,  WN34S Soil Temp x1, WH51 Soil Moisture x8,   WH55 Water Leak x4,   Meteobridge (TL-WR902AC v3),   Da9L PWT x2, Home Assistant Integration
