Weather Station Hardware > Blitzortung
GPS Year Error (1024 wk rollover) BLUE Systems with GlobalTop /Mediatek MT3333
(1/3) > >>
Cutty Sark Sailor:
Developers aware of issue, considering several options, in addition to, or instead of, updating.See
https://forum.blitzortung.org/showthread.php?tid=3648 in the INTERNAL forum for owners.
Mike
Mattk:
Would not think it is a standard 1024 GPS Week rollover issue (as such) but obviously sounds like some form of GPS timing issue and most likely very specific to this hardware?
Cutty Sark Sailor:
I keep hearing that it's not such.
  https://www.gps.gov/support/user/rollover/   e.g. https://www.gps.gov/cgsic/meetings/2017/powers.pdf
Cutty Sark Sailor:
A beta system firmware available... system will ignore year error, first step to correcting on server... should get system back up, signals nvald since RTC time is still -24 wks.  Install so devs can check is data is being sent.  Stations likely will show 'idle'... GUI may be erratic, as the script that drives GUI has to load from server, as in FW 9.2, and not onboard in firmware, as in <FW 9.1
https://forum.blitzortung.org/showthread.php?tid=3648&pid=24682#pid24682
92merc:
Is this just a system blue problem then?  I didn't see any mention of RED systems.
[#] Next page
