Weather Software > VP Tools (Virtual VP, VP Live, and VP Tools)
VPLive 1.1.5 Released - 29/Oct/06
(1/1)
W7DRM (old call was W3DRM):
I see Steve has released a new version of VPLIVE (http://www.softwx.com/weather/vplive.html - 29/Oct/06)
What's new in version 1.1.5
-Added option to write APRS data to a user specified file (such as WXNOW.txt).
-Significantly improved the robustness of the serial communications code to better handle catastrophic communciations failure of the device or device driver.
-Fixed a bug that sometimes prevented the communications retry logic from functioning properly.
-Changed the timing of attempts to re-establish communications - quickly at first, then scaling back to less frequent intervals if met with no success.
-Fixed a bug that sometimes caused the Connect/Disconnect menu item to fail to switch from Disconnect to Connect after an externally caused failure of the communications.
-Added feature for automatically restarting the console's USB device driver after a catastrophic failure.
-Added tray icon feature.
