Thank you very much for the response! I haven't been more excited about getting something up and running related to Davis in quite some time.
I did everything in your message except the 2nd high power entry (the void statement one). I decided to start from scratch, so I unzipped a brand new set of files and made all the changes per your message. I am still getting the same thing happening. To better explain it, all the numbers are zero when I boot up the console and go to the diagnostic screen. When data starts being received, it starts at 100% and then immediately to 50, and then 33, and it just drops down to there and ends up at 5 or 6%
I think I have it set up correctly for the most part. I let it run all last night and an outside temperature showed on the console but it wasn't updating, but a good packet or 2 must have made there way in there at some point overnight. When I look at the serial info, it looks like everything is working as it is supposed to.
Any other thoughts on anything I could be missing or should check?
Thanks Again!!!
1578423100 T 85-00-00-2E-CD-00-6A-EE-FF-FF 6 ----------/---------/----------/---- 38 - - 2937452 ok - - temp 74.8 (23.
1578443584 R 52-00-00-FF-71-00-C3-1B-FF-FF 3 151715440/3926025226/2466393097/187.2 16 -82 6 2689892 ok - - r_secs -
1581133492 R A2-00-00-16-3D-00-E8-62-FF-FF 3 168492656/3926025225/2466393097/187.2 17 -76 6 2689908 ok - - hum 79.0
1581298188 T E5-00-00-35-05-00-19-99-FF-FF 6 ---------/----------/----------/---- 39 - - 2875088 ok - - rain 53
1583111596 R 97-00-00-00-05-00-F9-10-FF-FF 8 2018642277/158880815/1601659250/9.0 6 -40 1 1978104 ok - - gust -
1583823352 R 82-00-00-2A-1D-00-6B-48-FF-FF 3 151715440/3926025226/2466393097/187.2 18 -75 6 2689860 ok - - temp 67.3 (19.6)
1584173264 T 55-00-00-FF-75-00-0B-5A-FF-FF 6 ---------/----------/----------/---- 40 - - 2920644 ok - - r_secs -
1586114008 R 87-00-00-2E-C9-00-E1-AE-FF-FF 8 2018642277/158880815/1601659250/9.0 7 -39 2 3002412 ok - - temp 74.8 (23.
1586513216 R E2-00-00-35-01-00-D1-D8-FF-FF 3 151715440/3926025226/2466393097/187.2 19 -75 6 2689864 ok - - rain 53
1587048264 T 65-00-00-38-05-00-8F-E8-FF-FF 6 ---------/----------/----------/---- 41 - - 2911864 ok - - solar 394
1589116668 R E7-00-00-80-05-00-87-D6-FF-FF 8 2018642277/158880815/1601659250/9.0 8 -40 2 3002660 ok - - rain -
1589923260 T 85-00-00-2E-CD-00-6A-EE-FF-FF 6 ----------/---------/----------/---- 42 - - 2903412 ok - - temp 74.8 (23.
1591892988 R A2-00-00-16-3D-00-E8-62-FF-FF 3 151715440/3926025226/2466393097/187.2 21 -76 6 5379772 ok - - hum 79.0
1592119372 R 57-00-00-FF-75-00-80-1A-FF-FF 8 2018642277/158880815/1601659250/9.0 9 -37 2 3002704 ok - - r_secs -
1592798336 T E5-00-00-35-05-00-19-99-FF-FF 6 ----------/---------/----------/---- 43 - - 2894788 ok - - rain 53
1594582888 R 82-00-00-2A-1D-00-6B-48-FF-FF 3 151715440/3926025226/2466393097/187.2 22 -84 6 2689900 ok - - temp 67.3 (19.6)
1595122016 R A7-00-00-BD-19-00-E0-E8-FF-FF 8 2018642277/158880815/1601659250/9.0 10 -42 2 3002644 ok - - hum 44.5
1595673308 T 55-00-00-FF-75-00-0B-5A-FF-FF 6 ----------/---------/----------/---- 44 - - 2886236 ok - - r_secs -
1598548364 T A5-00-00-BD-1D-00-6B-A8-FF-FF 6 ----------/---------/----------/---- 45 - - 2875056 ok - - hum 44.5
1599962640 R 52-00-00-FF-71-00-C3-1B-FF-FF 3 151715440/3926025226/2466393097/187.2 24 -77 10 5379752 ok - - r_secs -
1601127316 R E7-00-00-80-05-00-87-D6-FF-FF 8 2018642277/158880815/1601659250/9.0 12 -37 1 6005300 ok - - rain -
1601423384 T 85-00-00-2E-CD-00-6A-EE-FF-FF 6 ----------/---------/----------/---- 46 - - 2934668 ok - - temp 74.8 (23.
1602652524 R 62-00-00-7C-41-00-8B-08-FF-FF 3 151715440/3926025226/2466393097/187.2 25 -75 5 2689884 ok - - solar 874
1604129980 R 57-00-00-FF-75-00-80-1A-FF-FF 8 2018642277/158880815/1601659250/9.0 13 -40 2 3002664 ok - - r_secs -
1604298372 T E5-00-00-35-05-00-19-99-FF-FF 6 ----------/---------/----------/---- 47 - - 2926188 ok - - rain 53
1607132668 R A7-00-00-BD-19-00-E0-E8-FF-FF 8 2018642277/158880815/1601659250/9.0 14 -37 2 3002688 ok - - hum 44.5
1607173436 T 55-00-00-FF-75-00-0B-5A-FF-FF 6 ----------/---------/----------/---- 48 - - 2917560 ok - - r_secs -
1608032320 R E2-00-00-35-01-00-D1-D8-FF-FF 3 151715440/3926025226/2466393097/187.2 27 -83 5 5379796 ok - - rain 53
