Author Topic: Cumulus Stand-Alone Charts (beta available)  (Read 851 times)
Offline weather34
« on: October 18, 2016, 03:10:34 AM »
based on the wustandalone charts I created a version to read Dayfile.txt see screenshot below, has the chart structure was already built it was just a case pointing towards Dayfile.txt . i used the sample available at http://wiki.sandaysoft.com/a/Dayfile.txt to build.it took only 15 minutes to create because of the versatility of using canvasJs it is relatively same for all file types.
I would like to test this with some users if possible before I release it into the wilds . Not using using cumulus I dont fully understand all the possible options of what data or files is generated on a regular basis .
it is very easy to setup requires only the path to the Dayfile.txt or other txt files and uses a basic settings.php which has your location info , cumulus version.
so please drop me an email or pm with your path to Dayfile.txt so i can test it realtime and ill send it along for you too configure,customize if you wish.
its a really good alternative to running a database as you may as well reap the benefit of Cumulus generated data.
if i don't respond promptly I will get back to you at the weekends.
brian
« Last Edit: October 18, 2016, 05:51:08 AM by weatherist34 »
