Author Topic: firedangerWD.php script  (Read 344 times)
Offline SoMDWx
    • Southern Maryland Weather
« on: February 05, 2020, 08:06:39 AM »
Good morning all!
I was wondering if anyone knows how to crate a GIF image and store it to a file rather than having the script display the image when called...
I would like to have a physical file created from the image...
Thanks!
Jim
Offline gwwilk
  • Southeast Lincoln Weather
Re: firedangerWD.php script
« Reply #1 on: February 05, 2020, 08:53:30 AM »
As I recall, you're fairly handy at scripting, so this 'heavens.php' contains an example of just this sort of manipulation.
You can follow this variable to see what happens to it:
$pc_cacheFile = './cache/heavenpie.png'; // Relative path and name of cached image file
You can save the image in different formats, gif, png, or jpg by using the appropriate php function: imagegif(...), imagepng(...), or imagejpeg(...).
Hope this helps.
BTW, with 'firedangerWD.php' I've taken the opposite approach by using AJAX to update the image on my alternate dashboard in real time.
« Last Edit: February 05, 2020, 08:59:28 AM by gwwilk »
Regards, Jerry Wilkins
gwwilk@gmail.com
