Author Topic: battery level indicator - difference GW1000 <--> HP2551?  (Read 927 times)
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« on: August 04, 2020, 10:09:22 AM »
Hi!
Is the behavior of the battery level display between GW1000 and e.g. the HP2551C different?
From the GW1000 I know that the WH57 outputs the battery level in Ecowitt-format with 0..5, where 5 means full and 0 means empty.
Now I have a user with a new WH57, whose HP2551C reports the level as 0, although new batteries are in it.
So my battery warning mechanism fails of course - FOSHKplugin warns if the level is less than 2.
Could the HP2551 send a 0 if everything is ok and a 1 if the battery level is critical? So exactly how the GW1000 it does with the WH65?
So do I have to differentiate between the sending device?
That would be unpleasant ...
Does anyone have any experience?
Regards, Oliver
Offline mcrossley
    • Wilmslow Astro
Re: battery level indicator - difference GW1000 <--> HP2551?
« Reply #1 on: August 04, 2020, 10:19:32 AM »
Different devices report their battery status differently :( Some 0-5, some 0-1, some as a voltage!
Offline olicat
    • FOSHKplugin
« Reply #2 on: August 04, 2020, 10:28:55 AM »
Hi!
I know this behavior from the sensors.  I am only surprised that the weather stations behave differently.  Because the sensors always output the same data - regardless of the receiver.
Oliver
Offline mcrossley
    • Wilmslow Astro
« Reply #3 on: August 04, 2020, 02:56:27 PM »
Ah, sorry, I misread what you were saying.
Offline olicat
    • FOSHKplugin
« Reply #4 on: August 05, 2020, 09:58:37 AM »
Hi!
Lucy told me today that this behavior is not wanted but is a firmware bug that will be fixed by an update.
For all developers who use the custom server in the Ecowitt protocol as a basis: currently GW1000 and HP2551 deliver different battery levels with the same sensors. The reason for this is a firmware bug in the HP2551C.
Regards, Oliver
Offline olicat
    • FOSHKplugin
« Reply #5 on: August 30, 2020, 05:09:01 AM »
Hi!
Problem solved with firmware v1.6.7 for HP2551C - battery levels are shown on HP2551C as on GW1000.
Oliver
Offline wardie
Re: battery level indicator - difference GW1000 &lt;--&gt; HP2551?
« Reply #6 on: October 01, 2020, 04:27:14 PM »
Hi!
Oliver
Thanks. Given mine is a Froggit branded item from EU does that make any difference or is the firmware identical. I just checked my Froggit manual and the English section doesn’t tell you how to do a firmware update but the German section does. However it says go to their froggit.de website to get the firmware under support docs, but nothing is there on their site... Obviously I don’t want to brick it via a firmware no-no...
Sent from my iPad using Tapatalk
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
Offline olicat
    • FOSHKplugin
« Reply #7 on: October 01, 2020, 04:44:18 PM »
Hi!
Do not worry! Froggit uses the same firmware for the HP1000SE Pro as the original HP2551C.
Just download current firmware from Ecowitt and install this firmware:
1. Take out your microSD card(max 32G, Fat 32).
2. Drag the user.bin under the root directory of your microSD card.
3. Insert the card into the console -  power off the console - power on the console - update the program.
Oliver
Offline wardie
« Reply #8 on: October 01, 2020, 06:04:24 PM »
Hi!
Oliver
Thanks v helpful I’ll give it a go and report back.
WU: IKNEBW2
Online Gyvate
« Reply #9 on: October 02, 2020, 09:15:03 AM »
in fact, just re-inserting the SD card while the console is still running will already start the firmware update process.
Power-off /-on not needed.
That's good to know as you may interrupt the already started update process if you still pull the plug !!!
Or, alternatively, plug/power off, insert the SD card, plug in/power on.
« Last Edit: October 02, 2020, 09:16:38 AM by Gyvate »
