If johnd's idea doesn't work and you're determined to get it off, you can try backing it out with a drill bit. If you screw up the threads, a replacement vane is only $11.75 through SI. Or, drill it out completely and install a slightly bigger screw. It should hold fine I would think, very little resistance involved.
