Author Topic: any hope for a Radio shack PRO-82 that has vol problems? (JUNK)  (Read 4123 times)
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
I used to stream weather radio from my Radio Shack PRO-82 but now it seem like its volume is broken. I can have the volume max out and I can only just hear it ever so lightly. I am just about ready to junk it and give up on weather radios but I thought I would try here once before its a goner.
« Last Edit: June 29, 2014, 02:41:23 PM by Fox_Of_The_Wind »
Anthony
Offline corwyyn
  • Far, far east Mesa, AZ
    • Sleeping Saguaros Weather  Mesa, AZ
Re: any hope for a Radio shack PRO-82 that has vol problems?
« Reply #1 on: June 28, 2014, 10:52:11 PM »
So the volume is low on both the headphone and the main speaker? Sounds like the potentiometer on the volume control is shot, if that's the case it's repairable just need a new part and a soldering iron.
Kevin
AD5VG
Blitzortung station 1042
  • Hi there!
« Reply #2 on: June 29, 2014, 05:37:39 AM »
Yes it is low on the headphone and the main speaker.. Thanks. I will look into that part.
Anthony
Offline corwyyn
« Reply #3 on: June 29, 2014, 05:47:50 AM »
Ok to qualify I say it should be repairable but it's been a while since I opened up a RS scanner, but even if the potentiometer is a surface mount device it should be big enough that you can manually solder in a replacement. If you open it up and can post a pic it will help, meanwhile I'll do some 'net digging to see how common the failure is.
Kevin
AD5VG
Offline Cutty Sark Sailor
« Reply #4 on: June 29, 2014, 06:05:10 AM »
Sometime on pots it only takes a squirt of control cleaner and a few twists of the knob to restore operation,.. if corrosion, dirt is the issue...
  • Hi there!
« Reply #5 on: June 29, 2014, 08:03:27 AM »
ok lets see if I can post a pic.... https://www.dropbox.com/s/l85mgnof4zy9vtv/2014-06-29%2006.53.19.jpg
pic is too big for the forum so I left it on dropbox. If it don't load for anyone I will make it smaller and upload it here.
Anthony
Offline azkiwi
    • Maricopa, Sonoran Desert, Arizona
« Reply #6 on: June 29, 2014, 09:32:06 AM »
Anthony, that looks to be repairable.  Painstaking, but do-able.   It looks to be surface mounted with the 3 prongs going down into the circuit board.
Repair would mean carefully taking out the circuit board and flipping it over.  This should show the solder spots of the prongs.  Using a small soldering iron and a small solder vacuum (to suck up the molten stuff) it should be do-able.
If it was me, I'd try cutty sark's approach first.  Get a can of electronic cleaner from a Radio Shack and liberally squirt it down the shaft to the potentiometer  proper and rotate it back and forth a dozen times or so.  Might work.  For a while, anyway.
Ken
  • Hi there!
« Reply #7 on: June 29, 2014, 10:01:22 AM »
that is the strange thing. there is no play in it at all. I have had a few old radio were the vol started going and I could make them work by moveing that vol to the left or right.....I have not gave up yet on it.
Anthony
« Reply #8 on: June 29, 2014, 10:06:25 AM »
Ken
Assuming it's the pot... that looks like a so-called sealed pot... cleaner likely will NOT pass the shaft seal... if so, the pot's housing may have a tiny vent hole.  The cleaner needs to get inside the pot, onto the wiper(s) and resistive material. We'd use a syringe needle. If it's a 'graphite' resistive arc, cleaning may not help.  If the shaft wiggles a lot, it may be shot.. or the pot may be just loose in the board. Can of cleaner is good to have around anyway... there could be other reasons for low volume. even including a bad earphone jack!
BTW.. have you checked the battery terminals for corrosion, as well as any AC adapter jacks?  EDIT./// overlapping posts... I see you've eliminated shaft play... check it for 'axial' play, not horizontal...
« Last Edit: June 29, 2014, 10:08:45 AM by Cutty Sark Sailor »
Offline corwyyn
« Reply #9 on: June 29, 2014, 10:51:28 AM »
In addition to the above suggestions (all good by the way) one more thing you could do is just reflow the connections from the volume potentiometer to the circuit board - it may be as simple as a solder joint that's gotten weak over the years.
Kevin
AD5VG
  • Hi there!
Re: any hope for a Radio shack PRO-82 that has vol problems? (JUNK)
« Reply #10 on: June 29, 2014, 02:42:38 PM »
ok....today I tired to make it work again.....and it died...made a little bit of a smoke signal and the display went out..I did not even have time to take the vol off of it
Thank you all for the help.
Anthony
« Reply #11 on: June 29, 2014, 03:16:48 PM »
You didn't use something with high alcohol content, did you? #-o
  • Hi there!
« Reply #12 on: June 29, 2014, 03:25:11 PM »
I did not even have time to warm up my solder gun. At least it could have done for me was let me break it the right way.....now I have no clue what happened to it
Anthony
