Author Topic: New Blitzortung Firmware  (Read 299 times)
Offline ConligWX
  • #conligwx
    • conligwx.org
« on: January 28, 2024, 04:25:03 PM »
Just noticed Blitzortung now has v10.0 firmware available for BLUE and RED systems. (Beta)
https://docs.lightningmaps.org/station-operation/firmware/
10.0b2 Changes (2024-01-18) Beta Firmware:
show system type in header instead of "PCB"
prepared for BLUE-Mini development
fix: prevent saving settings during firmware download
fix: no output over USB after entering debug mode via button on startup
fix: crash on enabling USB-VCOM on RED
fix: LED/Buzzer IP signaling now does 10 ticks for digit "0"
10.0b1 Changes (2024-01-11) Beta Firmware:
new: encryption with AES-GCM and privacy options for signal packets
new: automatic firmware download and install
new: check signature of firmware
new: buzzer volume settings for ticks/beeps
new: option to disable webserver (i.e. for setups in foreign networks)
new: more privacy: do not send processor id, station id and position in signals to servers by default
new: sending signals without gps and/or just high precision counter value (on server request for GPSless TOA)
new: added Beidou GNSS option
new: support more GPS baudrates on BLUE
new: show CPU type and revision
new: support for ublox MAX-M10 GNSS module
new: ECDHE key exchange for remote config (enabling perfect forward secrecy)
fix: limited MTU to 1480 max
fix: not showing Galileo satellites due to missing ublox init
fix: warm start ublox GPS when firmware version can not be read
fix: SSI overflows on GPS status webpage
fix: compress packet only once for all servers
fix: stall on startup when network is up too fast (static config)
fix: sometimes not showing cert information in SSL debug messages
fix: weak encryption due to wrong random number generator configuration
updated lwip to 2.2.0
updated mbedtls to 2.28.6
updated CMSIS-DSP to 1.15.0
switched to arm-gnu-toolchain-13.2.rel1
lots of minor improvements and bugfixes
Regards Simon
Davis Vantage Pro2 Plus (6162UK) Daytime FARS WeatherLink Live AirLink PurpleAir PA-II-SD CumulusMX
Offline Vasco
    • PWS
Oregon Scientific WMR200 + Weather Display in Windows 10
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: New Blitzortung Firmware
« Reply #2 on: January 29, 2024, 05:54:04 AM »
no worries.  I didn't see that since the subject line wasn't that intuitive.
Regards Simon
Offline Vasco
    • PWS
« Reply #3 on: January 29, 2024, 06:50:33 AM »
True. . . but it was on the Blitzortung board  :lol:
