Do you have a reason as to why it should be in full sun?
WMO Standards:
In order to achieve representative results when comparing thermometer readings at different
places and at different times, a standardized exposure of the screen and, hence, of the
thermometer itself is also indispensable. For general meteorological work, the observed air
temperature should be representative of the free air conditions surrounding the station over as
large an area as possible, at a height of between 1.25 and 2 m above ground level. The height
above ground level is specified because large vertical temperature gradients may exist in the
lowest layers of the atmosphere. The best site for the measurements is, therefore, over level
ground, freely exposed to sunshine and wind and not shielded by, or close to, trees, buildings
and other obstructions. Sites on steep slopes or in hollows are subject to exceptional conditions
and should be avoided. In towns and cities, local peculiarities are expected to be more marked
than in rural districts. Temperature observations on the top of buildings are of doubtful
significance and use because of the variable vertical temperature gradient and the effect of the
building itself on the temperature distribution.
Source: Measurement of temperature - WMO Library
Personally, I try to follow these recommendations and place my sensors in the sunniest areas of the plot with free air flow.
I agree, In this case, no Davis Vantage pro, even if perfectly installed, complies with WMO regulations
we have to distinguish the shade of a screen according to the different scenarios:
- if the screen is in the shade for short periods, provided that this shadow concerns only the screen, and not the ground below, this is irrelevant for the purposes of a meteorological survey
- if instead, we talked about a comparison of performances between different shields, also in this case shading is not a problem, provided that all the screens under test enjoy the same shading and at the same moments, therefore they are always in the same conditions
Mauro
