Weather Station Hardware => Weather Web Cams => Bloomsky Sky Camera+sensors => Topic started by: Aardvark on January 01, 2017, 03:05:08 PM
I have two IP cameras already updating pictures to Weatherunderground. The weather data comes from Weatherlink.IP to my station on WU. I do that because running either Weathercat or Weatherdisplay on my imac slows down everything else. It can't be corrected so I use those two to get raw data and then go with that for my own uses.
The question I have, can I have only the sky camera send images to WU without having that data interfere with the data from the Davis VP2 station? I added the Storm but that isn't ready to send data until Bloomsky gets it done.
Just add a new station to your WU account using the Bloomsky. You can add the camera to that station. The data from each station is kept separate. I currently have two stations running under my WU account, used to be 3 stations until one quit working.
I thought about doing that. I suspect I will take your advice.
I did the station add but today I am getting "530 Login authentication failed" under the webcam upload. Do you have an answer for this?
