Interference, range, battery going bad in the sensor, something else... all of them. I mean it is a very low power radio transmission, for a reason, you run afoul of regulations , etc if the transmit power is too high. Also , the sensors for the most part (other than solar) are battery powered, increased power of transmission , lower battery life. Same reason some sensors that are battery only , have longer intervals between transmissions, battery conservation. The manufacturer has to work through all of that to get to a workable solution.
Edit: A good example in this is the WH41 and WH43, both PM2.5 sensors, but the WH43 is meant for indoor and should be USB powered and has a transmission rate of 1 minute (10 minutes if just running off batteries, in case of power outage I guess). The WH411 , OK, is meant for outdoor use, and although it has a solar panel, and rechargeable batteries, has a transmission rate of 10 minutes only. The difference is the WH43 was meant to be plugged in all the time, the WH41 not. (Although some of us have worked out a permanent power solution for the WH41, it will not alter the transmission interval). Other than power source, usb plug location, solar panel, both units are identical.
