In designing a potential station configuration, I plan to use a Leaf Wetness / Soil Moisture Transmitter to also monitor the air temperature inside my shed (along with the leaf wetness and soil moisture outside of it). The transmitter only has rj11 connectors for the leaf wetness sensors and has terminal blocks for the temperature (and soil moisture) sensors. Since the stainless steel two wire temp sensor (6470) is $65, the stainless steel rj11 temp sensor (6475) is $55, and the "regular" rj11 temp sensor (6477) is $30, my thought was to buy a "regular" sensor, cut the rj11 connector off, and then wire that to one of the block sets on the transmitter.
Has anybody done this? I would presume it works just fine?
