Weather Software => WeeWX Software => Topic started by: flyingvranch on July 18, 2021, 11:56:44 AM
I have Weewx installed and everything is running well. Because I was experimenting with the Davis Iss sensors and such I have a bunch of erroneous data that I need to get rid of. Now that everything is stable and running properly, how can I just delete the weewx database and start over fresh for my actual live weather data? I would prefer to clear out the old database and start fresh. Is there a proceedure or Linux command to accomplish this? Thanks!
If using debian or ubuntu, these commands should do it (this will remove both WeeWX and your user data but should retain your configuration):
sudo apt-get remove weewx
sudo rm -r /var/lib/weewx
sudo rm -r /var/www/html/weewx
Docs (search for uninstall): http://weewx.com/docs/debian.htm
If you installed using setup.py and you want to just delete the database then
sudo rm /home/weewx/archive/weewx.sdb
Thanks for the suggestions. As it turned out, I ended up just removing weewx and re-installing as it only takes just a minute to do so. As of now, everything is running smooth and stable and it sure is great to just have a completely quiet Pi running instead of the big desktop.
Thanks everyone!
