Author Topic: ambient weather .net with AW meteobridge acting weird  (Read 721 times)
Offline Platokidd
  • top side land of Lincoln
« on: November 05, 2021, 09:34:49 AM »
Dont know if this is just on my end or if others are having issues with ambientweather.net.
AW is acting weird on my end. Loads up okay but soon starts displaying empty screens.
1. open aw.
2.change between my stations
3.try refreshing the browser and nothing shows.
4.displays some data and shows empty data boxes at times.
5.tried 3 different browsers and on cell.
« Last Edit: November 23, 2021, 08:39:55 AM by Platokidd »
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
Re: ambient weather .net acting weird
« Reply #1 on: November 05, 2021, 09:42:52 AM »
Hi!
I only have one station (so can't switch) but there everything seems to be ok. Checked with Chrome and Firefox on Windows 10 and Ubuntu 16.04.
Oliver
Offline Platokidd
« Reply #2 on: November 05, 2021, 09:51:54 AM »
Starting to wonder if my aw meteobridge and the gw1100 sending data to aw is causing an issue.
https://ambientweather.net/dashboard/da8e5d5de2b001be9993f42733e15fa6
« Last Edit: November 05, 2021, 09:54:23 AM by Platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline olicat
    • FOSHKplugin
« Reply #3 on: November 05, 2021, 10:00:47 AM »
Hi!
Probably not.
I'am able to see your linked data with Chrome on a smartphone. But neither with Chrome or Firefox on the Win-PC.
So it seems to be more a problem of with page processing through AW ...
Did you try your link with a smartphone already?
Oliver
Offline Platokidd
« Reply #4 on: November 05, 2021, 10:11:11 AM »
Hi!
Probably not.
Oliver
Yes. It's the same issue.
So this could be more on AW end?
« Last Edit: November 05, 2021, 10:12:58 AM by Platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
« Reply #5 on: November 05, 2021, 12:38:30 PM »
Guessing AW can not handle all the senor data I was trying to send.
Meteobridge mapping with issue
Mapping without issue / removing 2 air and soil sensors. Seems to be working fine now.
Maybe will try adding those sensor again 1 at time.
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
« Reply #6 on: November 05, 2021, 03:26:36 PM »
Best I can figure since upgrading to SW Version: Meteobridge 5.2 (Nov 4 2021, build 14623), FW 1.4 making the air sensor the issue. (see red) After adding AW.net goes haywire.
I don't see a work around.
« Last Edit: November 05, 2021, 03:28:26 PM by Platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
Re: ambient weather .net with AW meteobridge acting weird
« Reply #7 on: November 23, 2021, 09:38:48 AM »
Think I finally figured this out. :shock:
1- on the GW1100 disabled the PM2.5 & pm10 & CO2 sensor.
This made AW dot net start working.
2- Then went back and re-registered the PM2.5 & pm10 & CO2 sensor.
Seems to be working fine.
However - only my outdoor pm 2.5 is showing on AW net. The inside pm 2.5 and the newer pm 2.5 & pm10 & CO2 sensor are not.
At times I have had both pm. 2.5's showing in the past on AW net.
My License will be ending soon on the AW Meteobridge. Have to figure out how and/or if I want to renew.
« Last Edit: November 23, 2021, 09:50:49 AM by Platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Online Rover1822
« Reply #8 on: November 23, 2021, 11:57:45 AM »
How does the data appear from your ws- 2000 when pointed at Ambient Weather . net. You may have multiple issues going on, then again, maybe not.  Part of the reason I bring this up, is when using the custom server option from the WS-2000, and Olicat's new tool to see what is actually sent, we observed that my WS-2000 was sending out a CO2 battery status, which is weird as I don't have one. And only the battery status was present, not sensor values. I know this may be totally apples and oranges, just seems like their may be something weird with the Ambient Protocol, or not working correctly.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Platokidd
« Reply #9 on: November 23, 2021, 12:54:40 PM »
The ws-2000 reads as it should and w/o issue now and so does my ws 2902a.. When I had the the issue with the meteobridge and gw1110, it would in fact wipe out all of aw . net. Could not read any of them. Just a blank screen or showing corrupted screen. The ws2000 and 2902a would in fact work fine before, that is until I looked at the data from the Meteobrige and gw1100 on aw . net. One quick peak and boom it's all gone.
Oddly enough, the feed from the meteobrige and gw1100 does show a temp sensor #9 on AW net. That is the c02 pm2.5 pm10 temps reading and I don't have 9 temp sensors.
Also noteworthy: The c02 pm2.5 pm10 sensor is Ecowitt branded and not AW. For whatever that"s worth.
When I have the time will try Olicat's new tool.
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Online Rover1822
« Reply #10 on: November 23, 2021, 01:09:22 PM »
P.S. I have no doubt , whatever web site admin, will be so appreciative of your input, and probably send you a Christmas gift. Not. But it all helps
FYI, Oliver's tool, my personal custom server, and wire shark all agreed on the data with mysterious CO2 batt status
I do recommend the tool, and has another use in this situation as you can look at what you are sending, as opposed to what the site is interpreting and displaying. So you can , in theory, determine if it is your issue, or the target site's interpretation as an issue.
Other Words, if you need to send something to the web admin of the site, you can point at your data and say, I'm sending this, you are displaying this, issue is not on the data side
P.S. I have no doubt , whatever web site admin, will be so appreciative of your input, and probably send you a Christmas gift. Not. But it all helps.
« Last Edit: November 23, 2021, 01:15:41 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline olicat
    • FOSHKplugin
« Reply #11 on: November 23, 2021, 02:06:04 PM »
Hi Platokidd!
With your multitude of sensors, I would almost wish that you would try sending it to ambientweather.net via FOSHKplugin.
All of my Ecowitt stuff goes this way to AW: https://ambientweather.net/dashboard/c6a4f228baea1e8caecc26d4f4b560bb
Would be nice to test your setup there.
What I do not understand, why does your license expire? License for what? Do you have to pay the AW MeteoBridge periodically?
I bought a lifetime license (VW-ANET) for this.
For connecting Ecowitt-devices to Ambient Weather via FOSHKplugin have a look here.
Oliver
Offline Platokidd
« Reply #12 on: November 23, 2021, 09:28:40 PM »
Greetings Oliver
Snippet from my AW Meteobridge license - Includes access to new releases until: 2022-03-01 I know it was good for 2 years when I purchased the device. Guessing I may be able to still use it without upgrades. Probably have to reach-out to AW guidance.
The FOSHKplugin looks interesting. Like a lot of weather geek stuff I see on the forum.  Will have to study and wrap my head around it. No doubt it would be a interesting challenge.
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Platokidd
« Reply #13 on: November 24, 2021, 08:34:16 AM »
Tried Oliver's tool last-night, pretty cool. It does show all of my data being sent from the gw1100. However is there a way to check what is being sent from the meteobrige?
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline olicat
    • FOSHKplugin
« Reply #14 on: November 24, 2021, 09:58:04 AM »
Hi!
If you can adjust the target ambientweather.net to ear.phantasoft.de this should work. But I don't know if there's the possibility in MeteoBridge to do so.
If not it would be possible with redirecting via DNS or just use WireShark (via your router) to see the http packages locally.
But this could get complicated.
Oliver
