Thanks Brian, what about the Access violation, in the 1st screen when i click test?
OK
OK
Parsed Port 22222,"dur
Parsed Port ->22222<-
OK
OK
OK
OK
OK
OK
OK
OK
ERROR: Access violation at address 00000000 in module 'crondaviswll.exe'. Read of address 00000000 at time/date 03:52:24 28/09/2021
Im not sure what issues there can be with the wifi, its the same wifi that WD is using.
What about Windows 10 pro issues? anything to do with the security in the firewall etc?
Does the crondaviswll.exe need adding to the security separately?
EDIT: is that what you mean? see image below, i just manually added crondaviswll.exe
to the windows firewall and as soon as i did the, that middle box came alive. Still no auto
detect mind and i still see that Access violation.
There is no wind at present to test this, sods law an all that...
EDIT: I've figured it out, I have use 10 minute average wind speed and use for max average ticked. Whilst that worked for the OS, Davis console and envoy, it obviously plays havoc with the WLL
Thanks for your time
