Weather Software > Weather Display
WD not reporting the correct windspeed and too slow inc dir
<< < (2/2)
Bashy:
--- Quote from: waiukuweather on September 27, 2021, 02:05:38 PM ---I do have a Davis WLL here myself and WD works perfectly with it
so it should be working OK for you
are you sure the IP address is set correctly?
have you tried the auto detect?
is the WLL device on the same WIFI network as your pc is on? (so that the separate running crondaviswll.exe program can pick up real time UDP data
i.e what shows in the separate running crondaviswll program?  ..the more detailed info you can provide the better (as I am not a very good mind reader you see))
--- End quote ---
Thing is, I don't know what info you need until you tell me, I'm am very new to WLL and like I said in the other thread with the other issues, wd cannot auto detect WLL, I think I did a video of that issue, not 100% sure though as I've done a few for other stuff of late (not weather related)
To answer your questions, yes, WLL is on the same network, I only have the one network, the IP is 100% correct, I don't think WD would pick up any data if the IP was wrong, could be wrong, but its deffo the right IP. Please see the image below, this is what the crondaviswll does...
Bashy:
and if i do auto detect through that app, i get this error, seen below, i think i mentioned it in the other thread too
waiukuweather:
the middle screen of the crondaviswll program is the UDP data
if that is blank, then that means the program is not getting UDP data
which is the real time data
so if its not getting that, then WD is not able to update at a fast rate, and instead is only getting the direct IP get data only
this will be related to your local WIFI Network (and is why the auto detect is not working)
Bashy:
Thanks Brian, what about the Access violation, in the 1st screen when i click test?
--- Code: ---OK
OK
Parsed Port 22222,"dur
Parsed Port ->22222<-
OK
OK
OK
OK
OK
OK
OK
OK
ERROR: Access violation at address 00000000 in module 'crondaviswll.exe'. Read of address 00000000 at time/date 03:52:24 28/09/2021
--- End code ---
Im not sure what issues there can be with the wifi, its the same wifi that WD is using.
What about Windows 10 pro issues? anything to do with the security in the firewall etc?
Does the crondaviswll.exe need adding to the security separately?
EDIT: is that what you mean? see image below,  i just manually added crondaviswll.exe
to the windows firewall and as soon as i did the, that middle box came alive. Still no auto
detect mind and i still see that Access violation.
There is no wind at present to test this, sods law an all that...
EDIT: I've figured it out, I have use 10 minute average wind speed and use for max average ticked. Whilst that worked for the OS, Davis console and envoy, it obviously plays havoc with the WLL
Thanks for your time
[*] Previous page
