Ok.. no worries. Looking at some entries for /conds.php accesses by meteobridge HTTP 68.80.214.133 - - [15/Oct/2020:07:04:51 -0500] "GET /conds.php?d=15/10/2020,08:04:41,12.4,97,11.9,1.3,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,26.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 301 579 "-" "meteobridge" atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:04:51 -0500] "GET /conds.php?d=15/10/2020,08:04:41,12.4,97,11.9,1.3,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,26.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 200 16 "-" "meteobridge" www.atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:01 -0500] "GET /conds.php?d=15/10/2020,08:04:52,12.4,97,11.9,0.9,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 301 579 "-" "meteobridge" atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:01 -0500] "GET /conds.php?d=15/10/2020,08:04:52,12.4,97,11.9,0.9,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 200 16 "-" "meteobridge" www.atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:08 -0500] "GET /conds.php?d=15/10/2020,08:05:03,12.5,97,12.0,0.4,1.3,151.0,0.0,0.0,1015.2,151.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.5,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 301 579 "-" "meteobridge" atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:08 -0500] "GET /conds.php?d=15/10/2020,08:05:03,12.5,97,12.0,0.4,1.3,151.0,0.0,0.0,1015.2,151.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.5,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 200 16 "-" "meteobridge" www.atglenweather.com 192.185.48.194
shows a somewhat odd pattern.
The first access via https for /conds.php?d= gets a 301 (document moved) return, and then the second access gets a 200 (Ok/success) return. That same sequence follows for all those accesses in the 10-15-2020 SSL log you provided.
It could be a Meteobridge quirk that causes it to try http first (despite the https in the URL), then following the 301 redirect to https. It also seems to be happening to /console/mbridge/mb.php Meteobridge HTTP accesses also, but NOT to non-Meteobridge accesses.
So, I'm thinking that the actual cause of the delayed conditions updates was due to the 1 minute interval change you'd cited in a prior post. It now seems to be reliably posting at 10 second intervals with timestamps on the access_log entries and meteobridge time/date in the conds.php?d= URLs in close agreement.
I think the original problem is now solved, and without logs for 10-14-2020, it's as far as I can go in debugging the issue.
