Weather Station Hardware > What Weather Station Should I Buy?
What weather station for a Boat
(1/1)
CombatDiver:
Hi
I already bought a Froggit HP1000SE and I tried to install in my boat
After a year, the axis, wind direction and speed, ended up not working, because they rusted ( no surprise at sea)
After I opened up, I say the poor construction it has. I carefully clean the inox axis, and return to live using grease. But as the electronics was so little and wiring very weak , some of the cables brokens, and I couldn't weld back as they cut off from the connector edge...
Anyway.. this station is not intended to be installed close to sea
I want some of you recommend me a model but with the following conditions:
- Must have like the froggit, UV radiation, wifi internet download, wind vane... etc
- Must have 5v dc powered
- And most important, I want to know if these that you can recommend me, are fine when you open up, showing me some photos, because I must open up first, and grease and protect all the exposed metals before install in a pole outside the boat.
- Of course not a marine or profesional grade, I just want to spend between 0- 350 USD
Well the best option should be a station built with 316 inox ( axis, and so )
But like this is very dificult, I want to know if I can open it without broken because is all chineese stuff and you can't even touch. Then If I can open, maybe I can replace the axis for a 316 maden pieces ordered in some place.
Any recommendations? ( I have see ACCUR8 DWS7100, but as I said, I dont know inside if it is ok...)
thanks a lot
Wooks61:
Have you thought about the WS80? (No moving parts to rust)
Have a look here for more information:
WS80 : https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#ws80
Lots of useful information in the Wiki:
CombatDiver:
Thanks for your advice!!
I didnt even know such a sensor was available
2 questions, if someone please...
1º This sensor is working even with the boat healing?
2º Can I use the froggit HP1000E display and reprogram it to use this WS80 or other different W.Stations?. I shaw SW is simillar...
Thanks a lot
Wooks61:
The WS80 can be used with the HP1000SE
Take a look at the Wiki:
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#hp2550_hp2560_-_ambient_ws-2000_ws-4000_ws-5000_-_froggit_hp1000pro_se_hp2000
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#the_main_display_interface_of_the_hp2550_2551_console_and_the_2nd_generation_hp2560_console
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#the_sensorsid_submenu_re-_registering_sensors
