Weather Station Hardware > What Weather Station Should I Buy?
Looking to set up 3 weather stations
nickk23:
Hi all,
The company I work for is looking to set up 3 weather stations across various properties we own. We want to be able to integrate them into a single webpage, making it easier for people at the company to view. I am unsure if we are ok with going cloud-based before the integration or keeping the data exclusively on our network before the integration. I have looked at Davis Vantage Pro2, Vantage Pro2 Plus, and Vantage Vue, with both the wired and wireless options for the Pro2 stations. I reached out to Tempest in regards to their TempestOne stations to see if this would be an option with their stations, and sent an email to METER to explore their options. I also started looking into Ambient Weather stations and ecowitt stations, but we would like as low maintenance as possible because of the locations we will be installing them.
We are not super concerned about cost, but I thought I would see what recommendations you would have as options.
I was planning on using a Google Site to display the data, as this can be restricted to people within our company. Hard-wired options will probably be better as we have login and password-protected Wi-Fi. We can likely make Wi-Fi options work though.
Sensor wise, we are mainly concerned with Temperature, Humidity, Wind Speed and Direction, Rain Fall and Rain Rate, Pressure, and at least one station with UV/Radiation monitoring. At least one station having a Lightning Sensor would be a plus, but not needed.
Thank you for your help!
Wooks61:
Very Useful information can be found here:
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start
R.Sidetrack:
Note that all weather stations are going to need periodic maintenance, no matter what brand of hardware you buy. At a minimum, someone will need to clean out the misc crap that accumulates in a rain gauge (leaves, bird crap, and anything else that falls out of the sky).
Ecowitt GW2000 and GW3000 gateways offer ethernet connections.
Personally, I suggest Ecowitt equipment. And I'd choose separate sensors (avoiding 7-in-1 type units), and include in the original budget purchase of spare components. If a sensor has a problem, you have a spare component ready to swap in. Since you have 3 properties, buy 4 sets of equipment so you have one spare of everything.
Keep in mind most of the more "famous" brands are working hard to make you pay ongoing fees to access the data from the equipment you just paid for. You won't have that issue with Ecowitt.
PaulMy:
--- Quote ---The company I work for is looking to set up 3 weather stations across various properties we own. We want to be able to integrate them into a single webpage, making it easier for people at the company to view. I am unsure if we are ok with going cloud-based before the integration or keeping the data exclusively on our network before the integration. I have looked at Davis Vantage Pro2, Vantage Pro2 Plus, and Vantage Vue, with both the wired and wireless options for the Pro2 stations.
--- End quote ---
That would certainly be one of the top of your consideration.
--- Quote ---I was planning on using a Google Site to display the data, as this can be restricted to people within our company. Hard-wired options will probably be better as we have login and password-protected Wi-Fi. We can likely make Wi-Fi options work though.
--- End quote ---
For quite a while the Davis approach has been Weatherlink.com and both the original console and newer Weatherlink Live and Weatherlink Console can tie into Weatherlink.com. But, in addition, Davis still has the Envoy console if running a program on a local PC is being considered for local data storage and customized uploads and website.
--- Quote ---Sensor wise, we are mainly concerned with Temperature, Humidity, Wind Speed and Direction, Rain Fall and Rain Rate, Pressure, and at least one station with UV/Radiation monitoring. At least one station having a Lightning Sensor would be a plus, but not needed.
--- End quote ---
Davis' UV and Solar sensor is professional. Davis does not have an optional lightning sensor.
Mattk:
Sounds like you have IT/network people who could integrate the data/web page etc? Hardwired, minimal maintenance, no maintenance rain gauge, Lightning, radiation, multiple/open communication interfaces/protocols then several of the Lufft WS-series/models meet those requirements
[#] Next page
