Author Topic: GW1000 connectivity issues  (Read 461 times)
Offline OntarioMC
    • CEDAR GROVE WEATHER HUB
« on: June 09, 2021, 06:07:47 PM »
I am hoping someone can help me resolve this problem. I am having an ongoing connectivity issue between Weather Display and my GW1000 hub.
I am running WD on a stand-alone laptop running 24/7 publishing my polished data online.
Things will be running along fine - and then the connection stops. The error message I receive in the CRON program is attached below. The second image is the message I receive when I reboot WD.
The interesting thing seems to be that the GW1000 seems to be 'viewable" by the CRON program and in the WSview app on my ipad - but no data is being received by either WD via CRON or on Ecowitt.net.
The only thing that seems to resolve this is to reboot my modem. Once I reboot my modem everything connects back up again and runs fine. Sometimes for a few hours - sometimes for less than 5 minutes. Then the whole thing disconnects again.
Very, very frustrating.
The GW1000 is set to static IP and the MAC addresses etc are all correct.
Thanks.
Mike
Offline broadstairs
Re: GW1000 connectivity issues
« Reply #1 on: June 09, 2021, 06:10:54 PM »
See my comments on the WD forum.
Stuart
Offline gszlag
  • ..have you calibrated your barometer today?
« Reply #2 on: June 09, 2021, 08:08:24 PM »
Thanks.
Mike
Is your GW1000 powered by plugging it directly in a phone/tablet type of AC adapter?
Your symptoms sound like mine when I plugged it in directly to the adapter. The GW1000 ran flawlessly out of-the box then developed random intermittent connectivity problems. It would lose its connection with the router and disappear from the network crashing the WeeWx driver. A hard reboot ( pull out the a/c adapter) would fix it temporarily but it would repeatedly go down a few times per day. Yep..frustrating.
I vaguely remembered some posts on this issue about adding a short usb extention cable and that was the instant cure for me..no issues since. If you haven't done so already..worth a shot.
Ambient Weather WS-2000
Ecowitt WS3900 console
Ecowitt GW1000/GW1100
Ecowitt WS68: Anemometer, UV/solar
Ecowitt WH40: Rain gauge
Ecowitt WH57 Lightning sensor
Ecowitt WH32E: Outside T & H sensor
Stratus Rain Gauge (manual)
Raspberry Pi 3B+ (WeeWX/CumulusMX)
Raspberry Pi Zero 2W (WeeWX/MQTT/Belchertown)
Barometer wiki: http://meshka.eu/Ecowitt/dokuwiki/doku.php?id=barometer#barometer
http://weather.glenns.ca (pwsdashboard - live)
http://weewx.glenns.ca
http://glenns.ca/cumulusmx2/index.htm
Uploading to: AWN, ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW
Offline Gyvate
« Reply #3 on: June 10, 2021, 04:32:51 AM »
some such similar symptoms show up every now and then - WD only - weewx, CumulusMX, Meteobridge are working properly with the same GW1000.
There is felt improvement with the latest GW1000 firmware (1.6.8 ) but this may be unrelated, because my other application software works/worked properly.
What helps in my case is just shutting down WD and starting it anew.
Do you use the latest crongw1000.exe ? (www.weather-display.com/downloadfiles/crongw1000.zip)
Offline broadstairs
« Reply #4 on: June 10, 2021, 06:50:27 AM »
I wonder if the physical orientation of the GW1000 could be important, when I selected my USB PSU for mine I arranged for the GW1000 to be mounted vertically as it would be if hung on a hook, some of the PSUs I have would not have allowed that. Just a thought....
Stuart
Offline OntarioMC
« Reply #5 on: June 10, 2021, 11:32:15 AM »
Thanks all for your suggestions - we (i.e. my wife) did some wizardy with the router settings and it seems to be holding its own (so far). I'm not 100% convinced that it is fixed but some progress at least. If it disconnects again - I will go through all of your possible fixes one at a time and watch for improvement.
All I have is WD - and I am pretty invested in it - so switching to another platform is not really in the cards for me right now. Will have to make it work somehow.
In terms of the latest CRON exe zip - I got it a couple weeks ago and it immediately solved the issue of no lightning sensor appearing in WD.
I also find it very interesting re: the issue with the ac adaptor and orientation of the GW1000 itself as I recently changed the adaptor from the one I had used initially.
Thanks again. Will keep posted if no improvement or if I discover the culprit in case anyone else ends up having the same problems as me.
Mike
