Author Topic: Weather34 template(non meteobridge versions)  (Read 119422 times)
Offline weather34
Re: HOMEWEATHERSTATION Dashboard template
« Reply #150 on: October 24, 2016, 10:25:26 AM »
Thanks Brian.  I used the "simpleupdate"method and all looks good.  The FAQ page is well done...
However I must have missed something in my reading as the full Contact form does not come up www.komokaweather.com/pws.  I just uploaded the added contactform folder in /pws/ and presume I need to do some edit?
Enjoying,
look fine here Paul screenshot attached
Offline giantocr
Re: HOMEWEATHERSTATION Dashboard icons updated
« Reply #151 on: October 24, 2016, 12:40:01 PM »
New icons updated for flurries,sleet and night time icons, icons are available via new area http://weather34.com/homeweatherstation/websiteicons/weathericons.html
the download includes PSD/SVG/PNG files currently they are currently named for weather underground forecast/current api service however you can adapt to other services just by renaming the icons to the appropriate name required by the service.
main template simple update for standard version only
the simple update zip file was updated with new contact form includes captcha security and many thanks to Piet http://www.weerstation-sauwerd.nl over the weekend for testing and eliminating the server config issue of session_start(),
contactform uses existing email set in the settings.php so there is nothing to configure if you have set $email = "something@dot.com"
also included change to moonphase.php,index.php,indexnew.php and css folder with changes to main.light.css/main.dark.css also includes new icons.to use just replace existing files/folders on server download at http://weather34.com/homeweatherstation/index.html
Replenishment
Replace in the folder contactform in the file contactform.php rule 109 by the following rule
<div style="font-family:Verdana, Geneva, sans-serif; font-size:16px; float:left; width:500px;" align="left"> <span style="color:#f26c4f;font-weight:normal;font-size:16px;"> <?php echo "$stationName \n"; ?> - </span> <span style="color:#00A4B4;">Contact Form
Then get you your own weaterstation name
See print screen
Furthermore you can in the same folder in the file index.php rule 20 still change on this way
$email_subject     = "Email recieved from  put here your own weather station name";
Then you can see what weather station the mail comes from.
Easy if you have several weather sites with its own email address
But first make a backup before you make the changes
Best regards en succes,
Piet
« Reply #152 on: October 24, 2016, 04:01:40 PM »
@Piet, that wxsim forecast on your site looks great.
I got the email function to work by simply clicking the mail envelope icon :oops:
All is good.
Thanks for looking.
Offline weather34
« Reply #153 on: October 25, 2016, 09:12:09 AM »
thanks to Piet once again ,http://www.weerstation-sauwerd.nl he continues to strive for using additional elements and software.
weather icons now compatible with WXSIM available at http://weather34.com/homeweatherstation/websiteicons/weathericons.html
was a case of renaming and resizing see how it turned out http://www.weerstation-sauwerd.nl
thanks to Erik Madsen for providing the language solution this will appear in November , he created a very simple easy solution to adapt
template to languages available. language contributions .. if you wish to contribute to the language files please send a PM i will send along the file in advance of release
its a very easy solution .
brian
Offline giantocr
« Reply #154 on: October 25, 2016, 09:26:21 AM »
The new Wxsim icons.
See print screen.
Thanks to Brian.
Piet
Offline weather34
« Reply #155 on: October 26, 2016, 11:03:06 PM »
thanks to erik and piet the translation part is almost done
Mid november will release translation version with a simple  choice setup
if you are interested in translating a simple file please get in touch via pm
full attribution will credit to yourself.
brian ...
« Last Edit: November 02, 2016, 02:54:01 AM by weatherist34 »
Offline weather34
« Reply #156 on: November 01, 2016, 10:07:14 AM »
we are progressing quite nicely now just awaiting 4 more translations and a few additional tweaks to be done and will release next week.
brian
« Last Edit: November 02, 2016, 02:53:46 AM by weatherist34 »
Offline weather34
Re: HOMEWEATHERSTATION Desperately seeking Translations
« Reply #157 on: November 02, 2016, 02:53:21 AM »
good morning almost ready to release the translated version but desperately seeking german and french as original offer as not materialised .
so if you are willing to translate a file please get in touch via PM or email
demo is available http://boutiquehotelitaly.net/babel/index.php?lang=en
apart from a few minor tweaks here and there this will be a public download next week and you a free to make your own translations to suit.
but would prefer a wider choice by default so please get in touch .
brian
« Last Edit: November 02, 2016, 02:56:43 AM by weatherist34 »
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
« Reply #158 on: November 02, 2016, 01:53:26 PM »
i'm very interested to this template.
I think the graphics part is the best in the template word but it's only one page :(
Is it possible to aggregate other pages to make a portal with some weather data?
I would use this template to make all these pages: www.meteocarmignano.it  except index page naturally.
Is it possible?
Thank you so much.
Regards,
P. S.
Now in test here: http://nuovosito.meteocarmignano.it
Alessandro
« Last Edit: November 02, 2016, 01:55:07 PM by i_fiorentino »
Offline weather34
« Reply #159 on: November 03, 2016, 04:25:35 AM »
Is it possible?
Thank you so much.
Regards,
P. S.
Alessandro
 i think i understand
you can adapt the template to a personal liking however it was designed as a dashboard though you can create a duplicate
layout(index?.php) and just replace module areas with what ever data you wish to use . need some experience in flexbox css and general php coding if you have that then no restrictions just down to your imagination.
have a nice day.
brian
Offline weather34
« Reply #160 on: November 06, 2016, 12:04:12 PM »
thanks to all the contributors over the last two weeks and glad to say we came up with a relatively good solution that will allow future updates and improvements without too much coding.
you can now download the UNIVERSAL LANGUAGE VERSION  at http://weather34.com/homeweatherstation
there was also minor update to the standard version
the translations are ongoing and only require a simple file replacement to update each time so be patient with us not all translators are weather enthusiasts some of the translators
are local friends here and myself being a foreigner living here in Istanbul the expat community is a small community where we get to meet many people from all over the world. most interesting translation
will be S.Korean by a student for his project no idea how that will turn out.
More goodness and something simply new to make even better user experience..
sometime this month also I will release something that was put back for some time due to focusing on other ideas . the next release mid November will have a
HOMEWEATHERSTATION EASYSETUP SCREEN . see screenshot below  . basically setup once and forget no more confusing mass of lines to edit .the easy setup panel has the necessary options to have it all up and running in minutes. click and forget . currently being beta tested but not expecting any issues as it was done months ago just needed some css styling. I am away for one week for a week without computers just a phone ,sand and sea and mountains..so don't worry if I don't respond to any emails or pm I will when I get back.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #161 on: November 06, 2016, 12:41:29 PM »
Hi Brian,
just a question, I know you said the translations are not complete, but I looked at the Czech version and please dont get annoyed, but it is awful and I don't believe this was done by a Czech. If I disregard the fact 80% of the strings are untranslated, even the ones that are are usually wrong, in two-word phrases only one is translated etc. Was this really done by a Czech person? The problem is that you even have a Czech flag in the languages on the main screen, but this is totally unusable (eg. wind direction translated as wind etc.). Some of the translations are funny, like "Full Moon" - we have a special word for it, but it was translated literally as "full moon", "daylight" translated as "game with light" etc. and someone who does not speak Czech cant spot this and they might include it in their template.
I dont want to be critical, you have done a great job with your template, but this seems to me a bit like half-baked product. I would wait until the languages are translated before including them in the download file.
One more thing.... I dont like people who criticize without saying what is the right way of doing things :-)
Attached is a translated CZ file. If you want you can use it.
Keep up the good work.
P.S.
Only thing I dont understand is this:
$lang['Falling'] = 'Klesající';
$lang['Rising'] = 'Stoupající';
$lang['Steady'] = 'Stabilní';
$lang['Rapidly'] = 'Rychle';
$lang['Temp'] = 'Temp';
What is "Temp" in the context of trends?
« Reply #162 on: November 06, 2016, 12:44:34 PM »
Hi Brian,
I have updated the standard version http://www.komokaweather.com/pws/ and all is fine...
well except for that annoying ongoing warning on my system...
Offline weather34
« Reply #163 on: November 06, 2016, 12:56:24 PM »
Hi Brian,
sorry to hear that paul wish I could help .
« Reply #164 on: November 06, 2016, 01:05:10 PM »
And the Universal version http://www.komokaweather.com/pws-ul/index.php?lang=en (not updating the cron files for this as yet so WU info will become stale)
No issue with the template Brian, it is just something in my system that gives that warning (also periodically in the Saratoga template and other scripts).
Offline weather34
« Reply #165 on: November 06, 2016, 01:16:39 PM »
Hi Brian,
P.S.
thanks for the cz file  it was added . many thanks .
brian
Offline droiddk
« Reply #166 on: November 06, 2016, 02:17:03 PM »
Nice job Brian!
Regards
Offline Jáchym
    • Meteotemplate
« Reply #167 on: November 06, 2016, 02:34:02 PM »
Hi Brian,
P.S.
brian
You are welcome, just if you could check that last trend string, either it shouldnt be there, or it should be something different or if it is supposed to be there then you should maybe explain it in a comment because others are probably not going to understand either what you mean by "Temp" in the context of trends and the words above it.
brgds
Offline erikmm
    • Hřrning By Vejr
« Reply #168 on: November 06, 2016, 05:26:13 PM »
Paul, which fault do you get?
Sent from my iPad using Tapatalk
Erik M M
Hřrning By Vejr
http://www.danmaach.dk
« Reply #169 on: November 06, 2016, 05:53:35 PM »
At the realtime update there is a warning which can be seen to pop up regularly - www.komokaweather.com/pws
  Warning:  file_get_contents(../pws/realtimePWS.txt): failed to open stream: Stale file handle in /home/content/96/5379896/html/pws/livedata.php on line 8
A similar message pops up occasionally on some other of my scripts.
Offline Jáchym
    • Meteotemplate
« Reply #170 on: November 06, 2016, 06:23:47 PM »
Paul,
try finding the corresponding line in the code and then paste somewhere in that file this:
function curlMain($url){
$ch = curl_init();
curl_setopt($ch, CURLOPT_HEADER, 0);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, 10);
curl_setopt($ch, CURLOPT_USERAGENT,"Mozilla/5.0 (Windows NT 6.1; rv:19.0) Gecko/20100101 Firefox/19.0");
$data = curl_exec($ch);
curl_close($ch);
return $data;
And then replace the file_get_contents with curlMain
like this:
file_get_contents("http://www.....");
to
curlMain("http://www.....");
Offline mickopla
    • Waterford City Weather
« Reply #171 on: November 10, 2016, 07:22:34 PM »
Hi Brian
Is there any skill to getting the forecast output to work? I enter my location of Waterford, Ireland and i get 25c forecast each day. We would be lucky to get that in the summer  :grin: Great job by the way
Offline dave_in_gva
« Reply #172 on: December 05, 2016, 02:08:47 PM »
Can someone tell me if this great work will function with the Froggit HP1003 console display?
This is a non-wifi clone of the Fine Offset HP1003. I would purchase from Germany and the transmission frequency is 868MHz.
The fact that it is not wifi enabled makes me wonder if it really qualifies as a WS-1001 clone.
Would be very nice if I could use this, as the display modification makes it much more attractive than the stock offering.
Best,
Dave M
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #173 on: December 05, 2016, 02:45:50 PM »
Very nice ! It is on my list to look it over in detail. I don't know if you are still supporting this or not. I went to your demo setup link and ended up on a dead page about Boutique Hotels in Italy. I am more of the Motel 6 kind of guy...LOL......
"I don't much about coding....but I did stay in a Holiday Inn once...." :grin:
Offline erikmm
    • Hřrning By Vejr
« Reply #174 on: December 05, 2016, 03:39:48 PM »
Garth Bock
This is the URL for the template
Erik M M
Hřrning By Vejr
