Author Topic: Ambient Weather Station Beta Testers needed :)  (Read 9713 times)
Offline SnowSentry
    • WeatherWizz
Re: Ambient Weather Station Beta Testers needed :)
« Reply #125 on: July 27, 2021, 03:39:24 AM »
Done :)
I have one more suggestion regarding the CO2 values on the first page:
could you add the unit (ppm) either under the word CO2 or under the value display ?
Offline Gyvate
« Reply #126 on: July 27, 2021, 03:42:17 AM »
great  [tup]
one little nit-picking: if there could be one empty line between the CO2 and the ppm would look even nicer 8-)
Offline Gyvate
« Reply #127 on: July 27, 2021, 03:43:58 AM »
and the CumulusMX string for the Ecowitt/Fine Offset extra sensor double page:
https://api.weatherwizz.com/api/update?stationid=XXXXXXXXXXXX&auth=XXXXXXXXX&wd=<#RecentWindDir>&ws=<#wspeed dp=1>&g=<#wlatest dp=1>&oc=<#temp>&r=<#rfall>&rh=<#rhour>&ap=<#press>&od=<#dew>&h=<#hum>&uv=<#UV>&oma=<#tempTH>&omi=<#tempTL>&wc=<#wchill>&it=<#intemp>&rr=<#rrate>&rm=<#rmonth>&ry=<#ryear>&fl=<#feelslike>&hi=<#heatindex>&sr=<#SolarRad dp=1>&temp1=<#ExtraTemp1>&temp2=<#ExtraTemp2>&temp3=<#ExtraTemp3>&temp4=<#ExtraTemp4>&temp5=<#ExtraTemp5>&temp6=<#ExtraTemp6>&temp7=<#ExtraTemp7>&h1=<#ExtraHum1>&h2=<#ExtraHum2>&h3=<#ExtraHum3>&h4=<#ExtraHum4>&h6=<#ExtraHum6>&h7=<#ExtraHum7>&sm1=<#SoilMoisture1> &sm2=<#SoilMoisture2> &sm3=<#SoilMoisture3>&sm4=<#SoilMoisture4>&sm5=<#SoilMoisture5>&co2=<#CO2>&co2_24h=<#CO2-24h>&ls=<#LightningDistance>&ln=<#LightningStrikesToday>&lt=<#LightningTime format="dd-MM-yyyy HH:mm:ss">&pm25_ch1=<#AirQuality1>&pm25_ch2=<#AirQuality2>&pm25_avg_24h_ch1=<#AirQualityAvg1>&pm25_avg_24h_ch2=<#AirQualityAvg2>&pm25_co2=<#CO2-pm2p5>&pm25_24h_co2=<#CO2-pm2p5-24h>&pm10_co2=<#CO2-pm10>&pm10_24h_co2=<#CO2-pm10-24h>&gd=<#wgustTM dp=1>
« Last Edit: July 27, 2021, 05:13:27 AM by Gyvate »
Offline SnowSentry
    • WeatherWizz
« Reply #128 on: July 27, 2021, 03:44:41 AM »
LOL Done!
 [tup]
Offline SnowSentry
    • WeatherWizz
« Reply #129 on: July 27, 2021, 03:58:49 AM »
Thanks for the url, I have updated it but removed the date time format for Lightning, if I have worked my magic correct it should format the serial date time to your local date time format.
Would you mind trying it and letting me know if the date time of the lightning is formatted correctly.
&wd=<#RecentWindDir>&ws=<#wspeed dp=1>&g=<#wgust dp=1>&oc=<#temp>&r=<#rfall>&rh=<#rhour>&ap=<#press>&od=<#dew>&h=<#hum>&uv=<#UV>&oma=<#tempTH>&omi=<#tempTL>&wc=<#wchill>&it=<#intemp>&rr=<#rrate>&rm=<#rmonth>&ry=<#ryear>&fl=<#feelslike>&hi=<#heatindex>&sr=<#SolarRad dp=1>&temp1=<#ExtraTemp1>&temp2=<#ExtraTemp2>&temp3=<#ExtraTemp3>&temp4=<#ExtraTemp4>&temp5=<#ExtraTemp5>&temp6=<#ExtraTemp6>&temp7=<#ExtraTemp7>&h1=<#ExtraHum1>&h2=<#ExtraHum2>&h3=<#ExtraHum3>&h4=<#ExtraHum4>&h6=<#ExtraHum6>&h7=<#ExtraHum7>&sm1=<#SoilMoisture1> &sm2=<#SoilMoisture2> &sm3=<#SoilMoisture3>&sm4=<#SoilMoisture4>&sm5=<#SoilMoisture5>&co2=<#CO2>&co2_24h=<#CO2-24h>&ls=<#LightningDistance>&ln=<#LightningStrikesToday>&lt=<#LightningTime>&pm25_ch1=<#AirQuality1>&pm25_ch2=<#AirQuality2>&pm25_avg_24h_ch1=<#AirQualityAvg1>&pm25_avg_24h_ch2=<#AirQualityAvg2>&pm25_co2=<#CO2-pm2p5>&pm25_24h_co2=<#CO2-pm2p5-24h>&pm10_co2=<#CO2-pm10>&pm10_24h_co2=<#CO2-pm10-24h>&gd=<#wgustTM dp=1>
Keep a copy of your current one :)
Offline Gyvate
« Reply #130 on: July 27, 2021, 04:13:48 AM »
unfortunately it then shows only hh:mm PM - a little helpful piece of information compared to full date time
that's why I started using the formatting " format="dd-MM-yyyy HH:mm:ss" "
There was also a correction in the string for gust - see my earlier posting marked bold
that's the actual peak value - and that's what's interesting to see imo
« Last Edit: July 27, 2021, 05:16:12 AM by Gyvate »
Offline SnowSentry
    • WeatherWizz
« Reply #131 on: July 27, 2021, 05:57:54 AM »
Any chance you can switch back to using no date format so i can see if it's possible for me to resolve it dynamically ?
Offline Gyvate
« Reply #132 on: July 27, 2021, 06:29:56 AM »
it's now sending without the formatting tag for a couple of hours - until it's hurting my eye too much.
Offline SnowSentry
    • WeatherWizz
« Reply #133 on: July 27, 2021, 06:47:07 AM »
Interesting, so the one you have removed the formatting from is sending the Lightning time as "7:32 PM", I was expecting the unix time stamp.  Is this CumulusMX?
Offline Gyvate
« Reply #134 on: July 27, 2021, 10:26:52 AM »
yes, CumulusMX - you have to use a specially formatted webtag to get the date as dd-mm-yyyy HH:mm:ss or any format (dd/mm/yyyy HH:mm:ss, or mm/dd/yyyy hh:mm, the latter will become hh:mm AM/PM depending) - the console sends EPOCH.
I can probably also tell CMX to send EPOCH, though. didn't work.  :-(
« Last Edit: July 27, 2021, 10:53:26 AM by Gyvate »
Offline funsutton
    • Weather Underground
« Reply #135 on: July 27, 2021, 01:49:14 PM »
Thanks for all the changes you continually make to your templates.
I only have a couple suggestions left.
1. Is it possible to put a pause button (pushpin) on the experimental template so i can stop it on the first page, or to just duplicate the primary page onto another template? I only have two temp sensors and there are times I'd just rather see the main page without it switching.
2. I wanted to drop you a one time donation but I couldn't find a way to do so. Maybe I missed it...?
Offline Rover1822
« Reply #136 on: July 27, 2021, 02:01:13 PM »
Any chance it will make coffee?
Don't hit me
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline SnowSentry
    • WeatherWizz
« Reply #137 on: July 27, 2021, 07:14:08 PM »
Hi funsutton,
Give template sew0001 in experimental a try, I have put some changes into that might accommodate what your looking for.   Also, can you let me know what device you are using this on, I would be interested to know if the resizing is working on tablets :)
I have added a paypal donation button for anyone who wants to help support this project, all help is appreciated :)
Offline funsutton
« Reply #138 on: July 27, 2021, 08:18:39 PM »
Aside from the max gust not populating, it looks and works great.
I am not using a small device. Rather I have a 12-inch ipad I bought some time back so I just have it set up beside where I work. And it looks great on it. I actually have my ambient console up over a door frame in my office to deal with reception issues, and it's far enough away that my aging eyes can't see it that well. So this is perfect.
But what makes this solution even more perfect is that I can pull it up on my phone and easily see my updated data when I'm not home.
Thanks for all that you've done with this. I hope it ends up being a great success for you.
Hi funsutton,
Offline WI1SKY
« Reply #139 on: July 27, 2021, 08:21:21 PM »
Sure liking this on my Davis VP2 / Meteobridge.  Very nicely done!
I'm not sure that I am ready to subscribe yet but would certainly like to donate.  I am not seeing a PayPal button, only the Patreon link.
« Last Edit: July 27, 2021, 08:24:26 PM by WI1SKY »
Offline funsutton
« Reply #140 on: July 27, 2021, 08:27:18 PM »
I didn't see it at first either. But it's there near the bottom.
Offline WI1SKY
« Reply #141 on: July 27, 2021, 08:36:12 PM »
You're messing with me; it wasn't there a minute ago!   :oops:
Offline SnowSentry
    • WeatherWizz
« Reply #142 on: July 27, 2021, 09:03:52 PM »
Thanks guys awesome donations, really appreciate the support  [tup]
Offline funsutton
« Reply #143 on: July 28, 2021, 01:12:30 AM »
Just fyi, sew0001 works great, but the max wind speed doesn't populate. Just showing -.-
Offline SnowSentry
    • WeatherWizz
« Reply #144 on: July 28, 2021, 01:16:28 AM »
Thanks for letting me know, I am looking into it.  Are you using meteobridge?
Offline funsutton
« Reply #145 on: July 28, 2021, 01:20:50 AM »
No. I'm sending it straight from my ambient console using the customized server.
Offline SnowSentry
    • WeatherWizz
« Reply #146 on: July 28, 2021, 01:22:09 AM »
Great thanks,  I mapped the wrong one on meteobridge, must have done the same on ambient, checking it out now :)
Offline funsutton
« Reply #147 on: July 28, 2021, 01:22:45 AM »
Looks like you got it fixed. Thank you!
Offline WI1SKY
« Reply #148 on: July 28, 2021, 12:48:43 PM »
I am not seeing any data in Apparent Temperature when set to "Feels Like".  If I change to Wind Chill/Heat Index, I get a wind chill temperature but that really isn't of value in the summer.
Offline SnowSentry
    • WeatherWizz
« Reply #149 on: July 28, 2021, 05:59:52 PM »
Hi WI1SKY!
If you select Feels Like you will only see this value if you station is sending it otherwise it will just show something like _._.
Wind Chill/Heat Index only work if you station is sending both values.
feel free to shoot me an email with you station id and I can checkout what data I am receiving.
support@weatherwizz.com
