Author Topic: meteoalarm.eu moving to new website and format  (Read 2721 times)
Offline steepleian
    • The Claydons Community Weather
Re: meteoalarm.eu moving to new website and format
« Reply #25 on: October 09, 2021, 02:32:11 AM »
i see meteoalarm.eu is no longer working and i have not seen an update for the meteoalarm scripts to us meteoalarm.org so the advisory link in the menu has been commented out on my  Saratoga templates https://www.hc-iom.co.uk/WD-AJAX/index.php and https://www.hc-iom.co.uk/WD-AJAX1/index.php (alternate dashboard) but check-fetch-times still tries to access the meteoalarm.eu site so takes a long time
I guess that meteoalarm has finally boxed me into a corner.. I'll be reworking the get-meteoalarm-warning.php script for the Saratoga template.   I'd been delaying it as their switch-over to the new site hadn't gone well, and some areas still didn't have alert data (like the UK).
Just to clarify the UK situation, UK data has been included since the launch of the new Meteoalarm. It is a bit misleading as the map shows as a whiteout unless an alert is in force. See the attached screen snippet from this morning where a yellow warning is in force.
Offline andy135
    • Chelmsford Weather Station
« Reply #26 on: October 30, 2021, 12:58:59 PM »
Just wondered if there will likely be an updated metoalarm script before winter starts in the UK? :grin:
Andy
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #27 on: October 31, 2021, 12:13:33 PM »
I just use the script from here.  it works....
https://www.willyweather.co.uk/info/widget/warning.html
you can chose between a full bar across the site or just a corner one, and you can also choose what corner/colour to use too.
Regards Simon
Offline andy135
« Reply #28 on: October 31, 2021, 01:03:15 PM »
Thanks - I am using this as an interim currently, however I would like to see the Meteoalarm version working again, if at all possible.
Andy
https://chelmervillage-weather.co.uk
Offline wsNoordbergum
    • wsNoordbergum
« Reply #29 on: November 20, 2021, 01:41:16 PM »
Meteoalarm is not reachable today, maybe it went offline?
Had a look at Aerisweather and made a developers account, so because my data is sent to PWS weather their API is for free.
Not sure how to implement the code on my site, Aerisweather has a good interface for selecting your warnings etc.
Works with JSON, guess I have to learn how to use JSON
As willyweather is only for UK users, no go for me...
Have a good weekend
« Last Edit: November 20, 2021, 01:44:22 PM by wsNoordbergum »
Davis Vantage Pro 2 UV/Solar
Meteobridge nano SD
Ecowitt WS90 WH40 WH31 WH57 GW2000 HP2550_c
CumulusMX/raspberry Pi 4b
