Author Topic: What is sunposa.php?  (Read 1090 times)
« on: February 03, 2025, 01:06:44 PM »
I have a broken link on my wxastromony page
https://bsmweather.org/wxastronomy.php
sun moon sky position graph
It will not load and when I click on it on my server a lot of errors come up...related to jpgraphs (which I still cannot figure out)
how can I fix it or delete it from the page.
Thanks--remember I am not a programmer.
Offline 92merc
  • BismarckWeather.net
Re: What is sunposa.php?
« Reply #1 on: February 03, 2025, 01:16:26 PM »
I believe it's the heart of the wxastronomy page.  But I'm opening your page just fine, no errors.
« Reply #2 on: February 03, 2025, 01:19:59 PM »
I am getting this in the middle of it
Mac/chrome
« Reply #3 on: February 03, 2025, 01:21:46 PM »
sunposa.php is a script that uses JPgraph to produce a graphic of the current sun and moon data.
Here's mine
To use it without errors, you have to upload (fully) the following directories and contents of
./jpgraph-4.4.2-sce-only/
./moonimg/
into your document root of your website.
You can see if you've done the uploads correctly by viewing https://bsmweather.org/sunposa.php?debug=y
It currently shows
sunposa.php Version 3.70 - 14-Dec-2024
..debug=y debugging output for sunposa.php.  PHP version 7.4.33
  Status of needed built-in PHP functions:
  function 'imagecreatefrompng()'  is available
  function 'imagecreatefromgif()'  is available
  function 'imagecreatetruecolor()'  is available
  function 'imagecolortransparent()'  is available
  function 'imagettfbbox()'  is available
  function 'imagettftext()'  is available
  function 'gregoriantojd()'  is available
  function 'curl_init()'  is available
  function 'curl_setopt()'  is available
  function 'curl_exec()'  is available
  function 'curl_error()'  is available
  function 'curl_getinfo()'  is available
  function 'curl_close()'  is available
  Settings used:
  lat='44.958018', lon='-93.944947', tz='America/Chicago'
  cacheFileDir='./cache/'
  moonImagePath='./moonimg/NH-moon'
  legendColor='orange' maxElevation='90'
--Warning: moonimg directory does not contain needed images.
  './moonimg/NH-moon14.gif' is missing.
  jpgraph location='./jpgraph-4.4.2-src-only/'
--Warning: JPgraph not found in jploc='./jpgraph-4.4.2-src-only/'
  Using internal calculations for moon data.
  moon image cache './cache/jpmoon.png does not exist.
  sun  image NASA  './cache/tempImg.gif exists.  Updated 2025-02-03 12:04:09
  sun  image cache './cache/jpsun.gif exists.  Updated 2025-02-03 12:04:09
  GD Library is available and has these capabilities:
    GD Version: false
    FreeType Support: true
    FreeType Linkage: false
    GIF Read Support: true
    GIF Create Support: true
    JPEG Support: true
    PNG Support: true
    WBMP Support: true
    XPM Support: true
    XBM Support: true
    WebP Support: true
    BMP Support: true
    TGA Read Support: true
    JIS-mapped Japanese Font Support: false
with the bolded lines showing the missing items.
« Reply #4 on: February 03, 2025, 01:45:15 PM »
I should let Ken have full reign over my server and clear up all issues
« Reply #5 on: February 06, 2025, 01:17:01 PM »
You are very close to having it work on your site.  I see that ./moonimg/ directory and contents are now on your site.
It's just the JPGraphs files that need attention.
If you're using FileZilla for FTP uploads to your site, just select the ./jpgraph-4.4.2-src-only/ in FileZilla and to a Put/Upload of all the contents.
When successful, you'll find the following directories on your site (with contents):
./jpgraph-4.4.2-src-only/src/
./jpgraph-4.4.2-src-only/src/barcode/
./jpgraph-4.4.2-src-only/src/fonts/
./jpgraph-4.4.2-src-only/src/lang/
./jpgraph-4.4.2-src-only/src/themes/
then sunposa.php will work correctly.
