Author Topic: WeatherStory quit working  (Read 1385 times)
Offline 92merc
  • BismarckWeather.net
« on: June 17, 2024, 11:26:10 AM »
I noticed my Weather Story quit working over the weekend.  Thought it was a fluke.  Apparently not.
My WFO is posting them.  I'm guessing they changed something.
https://www.weather.gov/bis/weatherstory
https://www.bismarckweather.net/wxstory.php
Thanks in advance.
Offline BKS97
    • Sartell East Weather
Re: WeatherStory quit working
« Reply #1 on: June 17, 2024, 11:48:53 AM »
92merc - Weather Story appears to be working OK here.
https://sartelleastweather.com/wxwxstory.php
« Last Edit: June 17, 2024, 11:51:03 AM by BKS97 »
Offline 92merc
« Reply #2 on: June 18, 2024, 10:16:11 AM »
I just noticed none of the sites I pick are working.  I'm guessing this is similar to the legend issue where gwwilk and I can't get that to work.  And GoDaddy is the cause...
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #3 on: June 18, 2024, 10:26:40 PM »
I also noticed that the Weather Stories were no longer displaying a few days ago. I was preoccupied with other script issues until this evening when I decided to have a look at the script.
Voila! A simple fix appears to work. Find in  DATA SETTINGS in wxStory_inc.php
$useCURL        = true;               // true=get data by cURL method  false=stream data
and change this switch to
$useCURL        = false;               // true=get data by cURL method  false=stream data
This worked for me with any WFO I tested, and I hope it will work for you, too.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline 92merc
« Reply #4 on: June 19, 2024, 08:43:31 AM »
Thank you for that.
